Face: invalid tolerance value
Re: Face: invalid tolerance value
I don't see OPenSCad as an addon. Where do I find this "binary"?
https://openscad.org/downloads.html It's an external program called by FreeCAD>
Thanks ED. Where to install it so that it's available as a workbench?
Install it wherever you normally install programs. The path to the executable is in Preferences|OpenSCAD
The OpenSCAD workbench is a standard FreeCAD workbench, has been since FreeCAD 0.13, it is not an addon workbench.56jimalexander wrote: ↑Sat Nov 20, 2021 6:54 pm Thanks ED. Where to install it so that it's available as a workbench?
Just select it like Part, Part Design etc You do have to go to select it as a workbench
Then go to FreeCAD Preferences should display Then selected the OpenSCAD icon should display First option is where the location of the OpenSCAD executable should be set if it has not defaulted to the correct location.
OK then! Thank you for clarifying all of this.
