Version: 0.20.26306 (Git) AppImage
Branch: (HEAD detached at 6701788)
Hash: 670178869ecdca52f7dcd332c513cb0c82b25cce
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
I know this must be really simple but I cannot get the sketcher carbon copy tool to work.
Following the instructions:
Make sure you are in the edit mode of an existing Sketcher Sketch. This sketch is the target of the operation.
Press the Sketcher CarbonCopy button.
Click on an edge from another sketch. This sketch is the source of the operation.
Geometry elements as well as constraints are copied into the active sketch.
Press Esc or the right mouse button to terminate the operation.
Example:
Step 1: create 2 sketches. One has only a circle, the other has only a square. Set both to be visible.
Step 2: Edit mode on the circle sketch. Click on the carbon copy tool.
Step 3: Try to click on an edge of the square in the visible second sketch and .....nothing happens. It does not select anything.
What am I missing?????
