Surface modelling with Mathmod workbench
Hi
I did search the forum. What I am looking for is a wrokbench, that can generate ISO and Parametric Surfaces.
There used to be a workbench based on Mathmod. Searching the forums reveals this, which is not very helpful.
There used to be an addon that could do this some years ago, but i can't find it in the add-on manager now. Can anyone point me to any direction? Thank you.
MY Freecad :
OS: Manjaro Linux (KDE/plasma)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.6
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
MY Freecad :
Branch: makepkg
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Surface modelling with Mathmod workbench
3D parametric curve (or ParametricCurveFP) can generate based on mathematical formulas.
HelloTheMarkster wrote: ↑Mon Nov 22, 2021 6:47 pm 3D parametric curve (or ParametricCurveFP) can generate based on mathematical formulas.
Thank you
Where do I find them and how to install them?
I found them in the macro installation dialog
But they dont seem to support the handling of surfaces.
I would appreciate a parametric surface creation tool.
For example, I would like to create this surface and give it a thickness.
Thank you.
Thank you.
ParametricCurveFP can create a closed bspline, but it does not support (at this time) attempting to make a face from nonplanar wires. Leave the Make Face property False if it is a nonplanar face. Go to Part workbench, and use the Make from wires tool to make the face. Set the FaceMaker property to Part::FaceMakerSimple or Part::FaceMakerExtrusion (must be typed in) for nonplanar wires. If these fail you might be able to make a face in the Surface workbench. Look also at Curves workbench, also installed from the addon manager.
If the object has self-intersections, as it appears to have from the image, that might also be a cause of failure with FreeCAD.
This is a non-interscting version of the same surface, being one order higher (third order enepper surface trimmed before intersection).
So, this means, I will have to create multiple such curves, at different r values in a spherical coordinate system and extrapolate them to form a surface ??
Then I need to calculate the normals and extract them as such?? this is going to be very clumsy and slow.
Thank you
Thank you
See if you can create this wire in ParametricCurveFP, and if so, show a screenshot of the settings needed. I think Part 3D offset might be able to work with the shape in the last image.
TheMarkster wrote: ↑Mon Nov 22, 2021 8:58 pm See if you can create this wire in ParametricCurveFP, and if so, show a screenshot of the settings needed. I think Part 3D offset might be able to work with the shape in the last image.
With some trial and error of the scalling factor, I have an Enepper Surface of 7th order, boundary only.
