Longitudinal cut in rotational shape
I am a complete beginner working with FreeCAD. I need to design a guide wheel for the old dishwasher (no spare part available). Creating a basic rotary shape was not a problem. I created a 2D model and let this shape rotate. But I would need to cut longitudinal slits in this unit at 60 degrees. What is the optimal procedure?
TIA
Milos
TIA
Milos
Re: Longitudinal cut in rotational shape
Now that your first post has been approved you may attach your file and images showing the part you wish to create. Longitudinal cuts in a rotational shape isn't really good enough as a description, at least not for me.
Thanks for your reply. I have included hand sketch of final shape. In red are cuts in rotational part that I aim at. Real dimensions of the wheel before cuts are in FCStd file (also included).
TIA
Milos
TIA
Milos
- KOLECKO_SE_ZLABKEM_ROTACE.FCStd
- (16.02 KiB) Downloaded 17 times
- WHEEL_DISHMACHINE.pdf
- (239.85 KiB) Downloaded 28 times
Make a sketch on the xy plane with a rectangle for the cut and do a pocket. Just do one of them. Then select the pocket and make a polar pattern with 6 elements.
- Shalmeneser
- KOLECKO_SE_ZLABKEM_ROTACE_SHALM.FCStd
- (16.47 KiB) Downloaded 18 times
Thanks for the hint. However I have more basic problem:
I have created Datum Plane and put an rectangle on it. I cannot set active corner points either for their invisibility or after tilting the plane I can see all edges and red points in cornes without making the points "active" (green) for setting dimensions and symmetry. Neither works an alternative when I created in sketch an rectagle on xy (z=0) - I can see the rectagle in the hole only.
I have played number of tutorials, but the majority of them were leaving fine control behind the scene (I have "retrieved" click "m" for changing the shape in multiline, spacebar for hiding,... )
Sorry for very basic details, but without "fine grained" info I could not find the proper path.
TIA
Miloš
TIA
Miloš
- HIDDEN_RECTANGLE.jpg (88.95 KiB) Viewed 1528 times
Use https://wiki.freecadweb.org/File:Sketch ... ection.svg to show the full sketch plane.
I have created final shape as depicted in picture FINAL_SHAPE.jpg (included). However there are some remnants from original 2D boundary and DatumPlane. Are these relevant in preparation for printing (slising)? How can I rid off these part of design? I am including the FCStd file for more details (KOLECKO_SE_ZAREZY_F.FCStd).
Is there any procedure how to validate final model?
TIA
Miloš
TIA
Miloš
- KOLECKO_SE_ZAREZY_F.FCStd
- (96.19 KiB) Downloaded 19 times
- FINAL_SHAPE.jpg (45.49 KiB) Viewed 1436 times
- Shalmeneser
Your DatumPlane has neither Map Mode nor Support. (so it is not just on the face !)
Seam line is normal.
- Capture du 2021-11-29 22-59-41.png (30.68 KiB) Viewed 1408 times
- KOLECKO_SE_ZAREZY_F_SHALM.FCStd
- (47.26 KiB) Downloaded 13 times
- Shalmeneser
- KOLECKO_SE_ZAREZY_F_SHALMv2.FCStd
- (54.93 KiB) Downloaded 16 times
- Capture du 2021-11-29 23-12-53.png (27.2 KiB) Viewed 1393 times
