Cannot export to stl file
squidgame
Post by squidgame »
Hello.
I would like to draw 3D file and print it out. I have draw a 3D file and exported it successfully.
But I needed to modify it.
So I have modified it and tried to export to STL in the same way.
But I have failed.
I have been trying to export it huge number of times but there was no STL file in the target directory.
I can see the different overlay icon in the "Pocket002", do it influence my problem?
Following is some messages in the Report view:
17:16:41 MDIVP::onSelectionChanged - unhandled: 5
17:16:41 MDIVP::onSelectionChanged - unhandled: 4
17:18:17 MDIVP::onSelectionChanged - unhandled: 4
17:18:17 MDIVP::onSelectionChanged - unhandled: 5
Following is some messages in the Python console:
>>> Gui.activateWorkbench("PartDesignWorkbench")
>>> ### End command Std_Workbench
>>> ### Begin command Std_Export
>>> __objs__=[]
>>> __objs__.append(FreeCAD.getDocument("cse_b63n2_bottom_v2").getObject("Body"))
>>> import Fem
>>> Fem.export(__objs__,u"D:/work/freecad/cse-b63n2/v2/sample.stl")
>>> del __objs__
>>> ### End command Std_Export
>>> Gui.runCommand('Std_Copy',0)
I have attached the source file....
Thank you in advance.
sample.FCStd
(94.06 KiB) Downloaded 19 times
Founder
Re: Cannot export to stl file
Post by wmayer »
You are using the wrong module to export to STL. The FEM module doesn't know how to automatically convert a PartDesign object (the body) to an FEM mesh.
Instead use the Mesh module to export to STL:
import Mesh
Mesh.export(__objs__,u"D:/work/freecad/cse-b63n2/v2/sample.stl")
Shalmeneser
Post by Shalmeneser »
* select the step in the construction tree
* File > Export :
** File Type : STL Mesh
** Name : ??
** Save
squidgame
Post by squidgame »
@wmayer Thank you for your reply. I have found that I have used a wrong menu. There is another menu for the STL file format.
I finally exported it to STL file with "STL Mesh (*.stl, *ast).
You have gave me a clue to solve my problem. thank you very much!
