Good afternoon.
I am new to FreeCAD and have a problem, my configuration is:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Italian/Italy (it_IT)
the problem is that the pad is not like i expect, i post some pictures
i can't attach the file because is too large(3777Kb),
Excuse me for my bad english and if i broke some rules of the forum, i hope someone can help me
Thanks
Pad problem
Re: Pad problem
.... hello, welcome to FC and the forum!
Greetings to the Community!
From the photos I deduce that it is a jack (I don't know if pneumatic or hydraulic), but without the file it becomes difficult to identify the problem, so you can attach the file by relying on a cloud service (setting the download not reserved).
Ti ricordo che puoi utilizzare anche il forum dedicato italiano.
Re: Pad problem
Hello, thanks for the answer, the object is a part of front fork of my bike, i insert the link to the file saved on my google drive account
https://drive.google.com/file/d/1pqgIvG ... sp=sharing
Re: Pad problem
Hello, greetings to the Community!
First you should optimize the workflow by making it as simple as possible (modeling progression), then moving the fillets and any chamfers at the end of the modeling (they negatively affect the eventuality of a geometric/dimensional change), then effectively constraining all sketches (using geometric rather than dimensional constraints as much as possible).
The problem you ask about is to be charged to Sketch008 (Pad004), open it and update it, perhaps placing the equality constraint on one diameter, then try to re-execute the offending pad function (the reason for the malfunction will probably be due to an error recalculation).
Un saluto
- Shalmeneser
Re: Pad problem
After Recompute of the body (from the first revolution), the pad then works.
With Part_CheckGeometry, problems begin at Fillet003.
(v 0.20)
(v 0.20)
Re: Pad problem
Thank you very much!...now it's ok!! ...but I did not understand how you managed to identify the problem, can you explain me?
thanks!
thanks!
- Shalmeneser
Re: Pad problem
Experience, luck, ...
Re: Pad problem
ok...thank you very much!!...i'm going practising!!
