I’m noticing that when I add a diameter constraint to a sketch, the text is cropped. Radius and other constraints display correctly though.
Is this an issue with FreeCad or with my setup/settings?
OS: Ubuntu 20.04.3 LTS (KDE/plasma)
Version: 0.20.26375 (Git) AppImage
Branch: (HEAD detached at 8a6e3d1)
Hash: 8a6e3d1b766a34546806b22d750929c2d00e30a6
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Text of diameter constraint getting cropped
- DiamterConstraintCropping.png (24.43 KiB) Viewed 785 times
Re: Text of diameter constraint getting cropped
I made a PR that was recently merged to fix this. Hopefully I didn't make the thing worse.
Will check commit number of the PR merge.
OK, should be right. Fix is 26475 (more or less 1, have to manually count because on a mobile).
I don't know the current commit used for AppImage but any later build would fix this issue.
I’ve just tried the 26498 appimage and yes, this issue does appear to be fixed. Thank you.
