drafted shape from string "letter of alphabet" does not allow an offset or thick solid or thickness operation
csteckel
Post by csteckel »
Hi all,
FreeCad is an amazing piece of software. Thanks to everyone involved.
I am trying to produce a single letter e.g. B to be hollow and open on the front. My first approach was
1) in Draft WB: Use "create shape from text", select Arial font, give it a letter B.
2) Part WB: pad/extrude the ShapeString.
3) Part WB: use "thickness" tool to give the B a thickness on its back and side walls. open in the front. select the front and open the thickness tool.
and from here it gets wonky. I have tried all modes, join types and intersect, self-intersect options. The results are all not expected and essential throws errors.
Second approach:
2) PartDesign WB: add empty body with extruded ShapeString; use "make a thick solid".
same wonky results as for the first approach.
Third approach:
2) in Draft WB: try give the ShapeString an any offset (preferably a negative one) to produce a copy.
3) in Part WB: pad/extrude both ShapeStrings and then execute the boolean operations to hollow out the letter
failed in step 2 when trying to offset the letter:
10:57:37  Traceback (most recent call last):
  File "C:\tools\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Draft\draftutils\todo.py", line 167, in doTasks
    Gui.doCommand(string)
  File "C:\tools\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Draft\draftfunctions\offset.py", line 130, in offset
    if DraftGeomUtils.hasCurves(newwire) and copy:
  File "C:\tools\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Draft\draftgeoutils\general.py", line 134, in hasCurves
    for e in shape.Edges:
AttributeError: 'NoneType' object has no attribute 'Edges'
I do not want to PartDesign a letter from raw elements as the goal is to produce all letters of the alphabet in different fonts and size and the cnc them from wood to have molds... I have tried different simpler letters e.g. T with no holes and curves. but the same wonkiness happend.
thanks for any hints. do I have to pre or postprocess the ShapeString in step 1 and then all is good? Ih ave played around with the Draft WB upgrade and downgrade. but no luck.
Carsten
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
offset_a_letter.FCStd
(13.18 KiB) Downloaded 23 times
Re: drafted shape from string "letter of alphabet" does not allow an offset or thick solid or thickness operation
Hi and welcome to the forum!
Thickness is one of the most picky functions in FreeCAD - or better in the third party geometric OCC kernel. This question comes up from time to time and it is not finally solved yet. You can play with 2D- or 3D-offset in Part workbench or perhaps can addon Curves workbench help you further.
I wonder why the T fails, because it is usually the B-spline curves which cause thickness to fail.
Willem
Post by Willem »
In Draft workbench convert a copy of Shapestring to sketch.
Delete the inside
Extrude the sketch in Part workbench,
Make a boolean in Part workbench of the 2 extrudes
papyblaise
Post by papyblaise »
I transform the B into a sketch, use the Arch workshop (hey yes) and mount a wall 0.5mm 5mm high
B.FCStd
(34.75 KiB) Downloaded 24 times
TheMarkster
Post by TheMarkster »
In Part workbench use 2D offset tool on the shapestring. Extrude both the shapestring and the offset and use one of the extrude objects to cut from the other. Place the cutting tool up in the z direction so the back wall remains.
Snip macro screenshot-00d00d.png (68.24 KiB) Viewed 1032 times
Unfortunately, this file fails check geometry with bopcheck enabled. It might not matter with this particular error.
b.FCStd
(71.86 KiB) Downloaded 26 times
domad
Post by domad »
Greetings to the Community!
The "Create Thickness" tool of the "Part" Workbench, in this case, works without problems for positive thicknesses (towards the outside), but when you try to create the thickness towards the inside, it works limited to a certain thickness depending on the size of the letter (hollow face), is documented in the * .gif
