Curves Workbench : Interpolation
seanx
Post by seanx »
Please considered the attached file.
Preview:
I have clicked on this button , saying "interpolate a 2D shape between two 2D curves.
I supplied the shape 1 and shape 2. Adding Sketch007 as hullcurve destroys everything :
And after that, if i remove the hull curve in the data tree, the failure does not go away.
I would like to :
1. Make the interpolation follow a path. That is, all the interpolated curves should be along sketch007.
2. The lines should be closed.
3. Individually select the 5th interpolated line (see highlighted), clone it, and increase it's size.
4. Then remove / hide the original 5th interpolated line
5. Draw a skin through all of these.
How can I do it. I understand it is pretty complex checklist, and I am asking for a lot. But any help is appreciated.
Thank you.
arm.FCStd
(39.77 KiB) Downloaded 30 times
My projects, among others:
https://linktr.ee/siderealNight
hammax
Re: Curves Workbench : Interpolation
Post by hammax »
... use identical sketches at both ends (and between).
arm_2.FCStd
FC.18.4
(57.99 KiB) Downloaded 25 times
seanx
Post by seanx »
hammax wrote: Sat Nov 27, 2021 2:44 pm ... use identical sketches at both ends (and between).
Thank you
What if i want different profiles?
Thank you
seanx
Post by seanx »
Also, How do I make this arm solid?
Selecting make solid shows error :
11:38:28 Attacher: linked object Part001 is unexpected, assuming it has no shape.
11:46:48 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:46:48 Creation of surface is not possible !
11:46:53 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:46:53 Creation of surface is not possible !
11:47:29 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:47:29 Creation of surface is not possible !
11:47:30 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:47:30 Creation of surface is not possible !
11:47:41 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:47:41 Creation of surface is not possible !
11:47:42 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:47:42 Creation of surface is not possible !
11:53:00 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:53:00 Creation of surface is not possible !
11:53:06 26Standard_ConstructionError BRepFill :: profiles are inconsistent
11:53:06 Creation of surface is not possible !
Please help.
arm_3.FCStd
(93.63 KiB) Downloaded 24 times
hammax
Post by hammax »
... you forced me finally to use this WB after installing a new Version FC19.2 in my also "new" PC.
Problem, you have too much frames in your pipe shape.
arm_3_2.FCStd
FC.19.2
(249.92 KiB) Downloaded 21 times
thomas-neemann
Post by thomas-neemann »
seanx wrote: Sat Nov 27, 2021 4:43 pm ..
is that a solution ?
https://www.youtube.com/watch?v=AMW9iSapU1E
phpBB [video]
seanx
Post by seanx »
hammax wrote: Sun Nov 28, 2021 12:39 pm ... you forced me finally to use this WB after installing a new Version FC19.2 in my also "new" PC.
With a lower Frame Count, the pipe wont properly fill up the hull curves. So i am in a catch there.
drmacro
Post by drmacro »
seanx wrote: Sun Nov 28, 2021 1:01 pm
Do you mean you need 20,000? What does that accomplish? :?:
hammax
Post by hammax »
... is that an arm of a 7 branch candle stick => Menorah ?
I tried frames number from (your) 60 downward til 20, when it first showed a shape.
Maybe there is another unknown parameter.
But I think the limit is caused by practise of airfoil design.
Try a half-profile.
seanx
Post by seanx »
hammax wrote: Sun Nov 28, 2021 1:53 pm ... is that an arm of a 7 branch candle stick => Menorah ?
Try a half-profile.
Is a test model of a biomimic arm.
I can't say more for now
I think freecad needs a biomimicry and a generative design workbench.
alas I am not that good in python. I can generate the shapes, but I dont knw how to interact with freecad
