Behavior of nested containers when moving with Manipulator WB
drmacro
Post by drmacro »
Not sure this is a Manipulator thing or a Std_Part thing... :?
Start with the following (note the position of the axis cross):
Snip macro screenshot-734604.png (119.13 KiB) Viewed 1819 times
Use transform to get this:
Snip macro screenshot-19b715.png (122.78 KiB) Viewed 1819 times
Now use Manipulator to put it back together by selecting the top of boss and the bottom of the hole in the pcb (again note the axis cross):
Snip macro screenshot-6b3242.png (130.03 KiB) Viewed 1819 times
But, delete the top level Std_Part (Controller With Mount Plate), keeping the contents, perform the same as above the pcb moves as would be expected and drag them all into a new Std_Part and all is good.
What is it about containers? :?
Is this a Manipulator issue?
drmacro
Re: Behavior of nested containers when moving with Manipulator WB
Post by drmacro »
Sorry for the pings, but, I'm not sure the subject is really making it obvious what this post is about...and not sure how to rephrase it to do so. :oops:
I think this is a combination of idiosyncrasies of nested Std_Part containers or a bug in Manipulator WB handling of nested containers, or some combination, or none of the above...
easyw-fc wrote: pinged by pinger macro
TheMarkster wrote: pinged by pinger macro
edwilliams16 wrote: pinged by pinger macro
easyw-fc
Post by easyw-fc »
drmacro wrote: Mon Nov 29, 2021 1:13 pm Sorry for the pings, but, I'm not sure the subject is really making it obvious what this post is about...and not sure how to rephrase it to do so. :oops:
There is an issue in Manipulator WB... it doesn't handle correctly an alignement when a top level 'Part' container has a non 'zero' placement.
There is a tool in kicadStepUp WB to reset the placement of a 'Part' contained assembly to 'zero', maintaining the actual position:
here the related forum thread:
https://forum.freecadweb.org/viewtopic. ... 17#p515417
drmacro
Post by drmacro »
easyw-fc wrote: Mon Nov 29, 2021 3:30 pm ..
Hmm...yes I remember that thread. But, in the attached version of the file in the images above, you'll note the container/s are not off origin. And applying the KiCADStepup tool doesn't change the behaviour.
(I had to remove some the other containers to get the file size down to forum allowed. )
ControllerPlusMountPlate-min.FCStd
(111.71 KiB) Downloaded 26 times
easyw-fc
Post by easyw-fc »
drmacro wrote: Mon Nov 29, 2021 4:01 pm Hmm...yes I remember that thread. But, in the attached version of the file in the images above, you'll note the container/s are not off origin. And applying the KiCADStepup tool doesn't change the behaviour.
I cannot display anything of your file... I can only see the objects in the combo View, but nothing in the 3D view area
drmacro
Post by drmacro »
Interesting.
If I open it in 0.19 I get the same, objects in tree, but nothing in 3D.
Fine in 0.20 though.
easyw-fc
Post by easyw-fc »
@drmacro,
unfortunately I cannot see anything in the 3D viewer also with:
OS: Windows 10 (10.0)
Version: 0.20.26498 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
drmacro
Post by drmacro »
It appears any FreeCAD that is using less than 7.6 OCCT won't display the file.
It loads, reports no error. Geometry check of items in the tree show no error or shape content.
drmacro
Post by drmacro »
The attached file has only been changed in 0.19 FC with OCCT 7.3.
I did notice the plate is not a 0,0,0. But, the Part containers are. This may be the source of the issue.
ControllerPlusMountPlate_min_7p3.FCStd
(106.38 KiB) Downloaded 20 times
easyw-fc
Post by easyw-fc »
drmacro wrote: Tue Nov 30, 2021 1:16 pm The attached file has only been changed in 0.19 FC with OCCT 7.3.
I have no issue in aligning parts... would you please post a video/gif of your issue?
