Panels behave differently when not docked
drmacro
Post by drmacro »
If I have the Properties panel and the Selection panel undocked, outside the main window. I get the following behaviour:
When FC looses focus and another application both panels fall behind the new app's window (this is as it should be)
When FC regains focus, the Selection panel pops in front, but the Properties panel does not.
This is inconsistent.
I think the correct behaviour should be both pop in front when FC gets focus.
This is with the configuration below (i.e. Debian, but works fine on Ubuntu though).
After turning off OpenGL in Preferences make no panel to front on get focus. Then setting it back, it remains that no panels receive focus when FC does. (At least now it is consistent :lol: )
Is it possible some other setting, FC or system, is effecting this?
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26507 (Git)
Hash: 9d70589d6c2f08f3339c40e9b990fde5863b45b7
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.6.0
openBrain
Re: Panels behave differently when not docked
Post by openBrain »
drmacro wrote: Mon Nov 29, 2021 2:03 pm When FC regains focus, the Selection panel pops in front, but the Properties panel does not.
I can't reproduce. Probably it has been fixed somewhere in between Qt 5.12 and Qt 5.15.
Or it is DE specific.
Anyway, would you be able to compile a tentative fix ?
drmacro
Post by drmacro »
openBrain wrote: Wed Dec 01, 2021 10:45 am ...I can't reproduce. Probably it has been fixed somewhere in between Qt 5.12 and Qt 5.15.
I suspect DE specific, or possibly multi-monitor. I can't reproduce on a single monitor system (Manjaro OS).
I think so. Just need to do git pull specifying the particular branch right?
openBrain
Post by openBrain »
drmacro wrote: Wed Dec 01, 2021 1:07 pm I think so. Just need to do git pull specifying the particular branch right?
Nope. Ideally you should cherry-pick from my repo but it can be a mess if you are not so used to git.
I'll create a draft PR and give you procedure to test. ;)
openBrain
Post by openBrain »
OK, I created draft PR5216, so to try it :
git fetch origin pull/5216/head:PR5216 #if origin is your own fork, use 'upstream' instead of 'origin'
git checkout PR5216
Then run your normal build process.
When you're done with testing, you can delete the local branch with
git branch -D PR5216
drmacro
Post by drmacro »
openBrain wrote: Wed Dec 01, 2021 1:27 pm
git checkout PR5216
Hmm...for my edification (and maybe peace of mind). I keep, I think, the origin source in a local directory. Daily I do "git pull", then in a local build directory do the cmake and make.
Normally for all other trial builds I create a new local directory for the source and build. Typically with a "git clone <git> <local dir>"
Basically I want to understand how I get back to what I have before the fetch (assuming following your instructions).
Sorry, I have the O'Reilly git manual and this stuff still eludes me. Ok the day I'm reading and doing it, but, 6 weeks later...deer in the headlights. :? :(
openBrain
Post by openBrain »
drmacro wrote: Wed Dec 01, 2021 1:42 pm Hmm...for my edification (and maybe peace of mind). I keep, I think, the origin source in a local directory. Daily I do "git pull", then in a local build directory do the cmake and make.
No problem. Can you give me your
git remote -v
and
git branch
so I can make better than a general "not so clear" answer ?
drmacro
Post by drmacro »
$git remote -v
origin	https://github.com/FreeCAD/FreeCAD.git (fetch)
origin	https://github.com/FreeCAD/FreeCAD.git (push)
$ git branch
* master
openBrain
Post by openBrain »
drmacro wrote: Wed Dec 01, 2021 1:51 pm
$git remote -v
$ git branch
* master
OK, so your origin is on FreeCAD master repo.
So basically what will happen :
Will fetch the PR I created (actually just the difference with master, saves bandwidth) in a new branch called 'PR5216' --what is after the colon sign-- so you will get something like :
$ git branch
* master
* PR5216
Then
git checkout PR5216
will switch your local copy to the newly created branch (so code with my PR included).
Just compile and run
When it's done, switch back to master branch with
git checkout master
And finally delete the PR branch with
And you're back to original state as if you had never tested the PR :)
drmacro
Post by drmacro »
Unfortunately it made no difference. Selection view, Report view, Python console all pop forward but not Properties. :(
Version: 0.20.26519 +1 (Git)
Branch: PR5216
Hash: fb94b177cbb6bb37113404d0daa1516ee29b11aa
Qt version: 5.11.3
