Curves & Surface WB segfault
drmacro
Post by drmacro »
When I attempt to make a surface between the yellow curves shown FC segfaults.
There is a significant amount of error output at the terminal (the beginning is shown below) I'm guessing from the words handle, bspline, and opencascade the segfault is coming from OCCT and probably much can be done by FC?)
Snip macro screenshot-9881c1.png (78.7 KiB) Viewed 1595 times
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7f8a82d6f840]
#1  0x7f8a29d33220 in Geom_BSplineCurve::Degree() const from /home/mac/occt760b-install/lib/libTKG3d.so.7+0
#2  0x7f8a2a78f73e in GeomFill_BSplineCurves::Init(opencascade::handle<Geom_BSplineCurve> const&, opencascade::handle<Geom_BSplineCurve> const&, opencascade::handle<Geom_BSplineCurve> const&, opencascade::handle<Geom_BSplineCurve> const&, GeomFill_FillingStyle) from /home/mac/occt760b-install/lib/libTKGeomAlgo.so.7+0x4ce
#3  0x7f8a2a791aed in GeomFill_BSplineCurves::Init(opencascade::handle<Geom_BSplineCurve> const&, opencascade::handle<Geom_BSplineCurve> const&, opencascade::handle<Geom_BSplineCurve> const&, GeomFill_FillingStyle) from /home/mac/occt760b-install/lib/libTKGeomAlgo.so.7+0x42d
#4  0x7f8a1f61e202 in Surface::GeomFillSurface::createBSplineSurface(TopoDS_Wire&) from /home/mac/fc-daily-build-occt760b/Mod/Surface/Surface.so+0x622
#5  0x7f8a1f61e38b in Surface::GeomFillSurface::execute() from /home/mac/fc-daily-build-occt760b/Mod/Surface/Surface.so+0xab
#6  0x7f8a8636a3a2 in App::DocumentObject::recompute() from /home/mac/fc-daily-build-occt760b/lib/libFreeCADApp.so+0x102
#7  0x7f8a3198ef6b in Part::Feature::recompute() from /home/mac/fc-daily-build-occt760b/Mod/Part/Part.so+0xb
#8  0x7f8a863081fc in App::Document::_recomputeFeature(App::DocumentObject*) from /home/mac/fc-daily-build-occt760b/lib/libFreeCADApp.so+0x2dc
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26507 (Git)
Hash: 9d70589d6c2f08f3339c40e9b990fde5863b45b7
Python version: 3.7.3
Qt version: 5.11.3
OCC version: 7.6.0
AdvancedFillet.FCStd
(25.93 KiB) Downloaded 18 times
Vincent B
Re: Curves & Surface WB segfault
Post by Vincent B »
Your file seems corrupted. :roll:
AdvancedFillet2.FCStd
(89.1 KiB) Downloaded 10 times
user1234
Post by user1234 »
AdvancedFillet_edit.FCStd
(24.49 KiB) Downloaded 14 times
Greetings
user1234
drmacro
Post by drmacro »
Vincent B wrote: Mon Nov 29, 2021 9:42 pm Your file seems corrupted. :roll:
Hmm...same file worked later making the surface with Sweep on two rails.
I thinking the OpenGL and the gpu on this machine get some sort of issue. :roll:
user1234
Post by user1234 »
drmacro wrote: Mon Nov 29, 2021 10:44 pm Hmm...same file worked later making the surface with Sweep on two rails.
Sweeps on two rails? Please tell me more! I never was able to do that, not in Part or PartDesign. Of course i also look in the wiki.
Greetings
user1234
edit: removed unnecessary comment
drmacro
Post by drmacro »
user1234 wrote: Tue Nov 30, 2021 12:59 am ...
Curves workbench, MangoJelly covers it pretty well:
https://youtu.be/8JO3kU3Lg-U
drmacro
Post by drmacro »
Actually during work on other posts, I've determined that files saved with OCCT 7.6 appear empty of shape data when opened with FC using less than OCCT 7.6.
But, it makes no difference to the error:
Peek 2021-11-30 08-25.gif (347.64 KiB) Viewed 1311 times
drmacro
Post by drmacro »
But, if I change the order of selection it works. :o
Peek 2021-11-30 08-43.gif (490.59 KiB) Viewed 1289 times
user1234
Post by user1234 »
Yes, it seems to work very selective.
Greetings
user1234
onekk
Post by onekk »
In some post, @Chris_G has told me that Sweep2rails, is "old code" and Gordon Surface has to be used instead.
https://forum.freecadweb.org/viewtopic. ... 26#p561226
Maybe it is better to ask him about this thing.
Regards
Carlo D.
- Various other stuffs.
