Sketcher - Processing issue
Pauvres_honteux
Re: Sketcher - Processing issue
Post by Pauvres_honteux »
abdullah wrote:
Wonder if using some sort of "is_touched"-flag could be exploited here?
For example: attach a "flag" to each element and then 'just' check them. I don't know, but in my world it sounds cheap with respect to cpu clock cycles?
abdullah
Post by abdullah »
Pauvres_honteux wrote: Fri Dec 03, 2021 6:26 am
Reality is more complicated than that.
There two sides:
a) the change on the sketch does not modify the end shape generated, but intermediate operations changed the end shape (Auto-update on).
b) the change on the sketch does not modify the end shape generated and the intermediate operations did not change the end shape.
c) the change on the sketch modifies the end shape, but I really wished I hadn't modify the sketch at all, so I want to cancel.
d) the change on the sketch modifies the end shape and I want to modify it.
in a) you need to recompute the shape and this will trigger recomputes on all dependant objects. No way to avoid this.
in c) one can generally undo the operations. There could be a functionality to undo everything in one go (set the properties back to the state they had upon entering the sketch in edit mode). I am not sure how much such a feature would be used. It is likely something in the order of 0,1% of the cases. However, here you will need to solve and recompute.
in d) you need the recompute.
This leads to the very specific case b). Here you have:
case b1) you did modify the sketch object, but your modification did not modify the end shape (you added reference constraints or construction geometry only).
case b2) you did not do anything at all (open/close).
In b1) you definitely need to solve the equation system, but you could spare the recompute. In b2) you could spare both.
The problem here is tracking the changes. I guess one could leverage the hash of each geometry, excluding the construction ones. I am unsure however, if this would be meaningful having regard to the frequency of occurrence of such event.
In fact, I would go deeper into what is the root cause of entering edit mode of a sketch in case b2. If the issue is that one does not know what is being opened, then the solution might rather come from helping the use better decide what to open (for example by visual aids before entering edit mode).
Pauvres_honteux
abdullah wrote: Sat Dec 04, 2021 5:56 am
Make Auto-update "flag"-aware? I mean, if user did something that did not affect the end shape or its orientation, then I, as a user, expect the sketch to remain "untouched" and therefor shall not be updated at all.
With the flag principle it would just be a matter of checking "is_touched flag" set or not. No need to compare anything.
TheMarkster wrote: Wed Dec 01, 2021 2:10 am ... make a copy of the sketch when opening the task dialog, and then when the user cancels restore the sketch from the copy.
Adding: if "is_touched"-flag is set then delete sketch copy.
Here the "is_touched"-flag is set. Go ahead and do what is done today, i.e. no change of behaviour.
This will be on the user account. She/he will be fully accountable for clicking the recompute button. No shadow shall fall on the programmer in this case.
Same goes for "Auto-update on".
in c) ... I am not sure how much such a feature would be used. It is likely something in the order of 0,1% of the cases.
Hmmm, 0,1% = 1/1000 of opened sketches. That sounds too low compared to what I'm experiencing at work.
Hashing, I would say, sound like an excellent idea!
... what is the root cause of entering edit mode of a sketch in case b2. If the issue is that one does not know what is being opened, then the solution might rather come from helping the use better decide what to open (for example by visual aids before entering edit mode).
All visual aids are welcomed with open arms! Even small aids goes a long way.
abdullah wrote: Sat Dec 04, 2021 5:56 am in c) one can generally undo the operations. There could be a functionality to undo everything in one go (set the properties back to the state they had upon entering the sketch in edit mode). I am not sure how much such a feature would be used. It is likely something in the order of 0,1% of the cases. However, here you will need to solve and recompute.
I would rate this higher. If a recompute could be avoided, then this would cover b2 as well.
I do this quite often, and for me it would be sufficient if only this use case was improved with not recomputing. One rather special and thus in general neglectable use case is my work as helper here, where I check many foreign sketches. But I do this with my own models too, inspect references, look up names, ...
abdullah
Post by abdullah »
chrisb wrote: Sat Dec 04, 2021 10:04 am I do this quite often, and for me it would be sufficient if only this use case was improved with not recomputing. One rather special and thus in general neglectable use case is my work as helper here, where I check many foreign sketches. But I do this with my own models too, inspect references, look up names, ...
Ok. Put it in the tracker and I will eventually take a look.
abdullah wrote: Sat Dec 04, 2021 11:19 pm Thanks!
issue #4797
leoheck
Post by leoheck »
I also would say that my rate of entering on edit mode is definitely pretty higher than that.
Actually, I enter the edit mode, every time. I would rather call it to view mode. Where I can (re)view my constraints. Otherwise, I have to guess what I made before.
another problem of recalculating every time it is not the recomputation itself, but the domino effect that, then, recomputes the next features and also other linked objects.
leoheck
Post by leoheck »
This cancel button - that reverts to a previous copy of the feature - could be applied to this scenario too.
Here one more digit was entered on the input field by mistake (this happens a lot). Far more than 1/1000.
And don't get this wrong. But the operation does not succeed yet. The green text is an old text. It should have been updated before doing the computation to something like... "Processing the transformation..."
Then Freecad dies. There is no escape from it. The operation has to end or I have to close the software. Closing the software is the worst thing that may happen.
I cannot confirm now since this thing is still processing... but one possible way to harden this is to have the whole text selected when the input field is clicked, any mistake will override the old value. But the same issue still may occur.
adrianinsaval
Post by adrianinsaval »
uncheck update view for stuff that takes a lot to process
Pauvres_honteux
leoheck wrote: Wed Dec 15, 2021 6:50 am ... another problem of recalculating every time it is not the recomputation itself, but the domino effect that, then, recomputes the next features and also other linked objects.
Hi leoheck, that particular thing may be covered by this feature request: [Ticket #4728] Local update function/button
In short it would "recompute up to here", that is, where you set Tip or where you right clicked and chose "recompute up to here" in the popup menu.
