Move entire body on x/y plane
I created a body with several sketches and references and attempted to execute a cut path on one of my sketches (sketch004) when I reached an outer limit on my CNC bed. Now I need to move the entire part so I can reference a new 0,0 point so I can mount the same part further down on the bed. My lesson learned here is to center my part on the x/y plane so I can put it anywhere on the bed. What steps need I take to accomplish this?
- left leg back support pockets.FCStd
- (94.64 KiB) Downloaded 8 times
- Shalmeneser
- Shalmeneser
Re: Move entire body on x/y plane
btw :
* Sketch004 on Face = TNP
* Sketch004 on XY_plane =
* Sketch004/005/006 sketches : seems over-complicated imho
* Pocket001+002 = you should use PartDesign_Hole
- Capture du 2021-11-30 19-58-37.png (25.01 KiB) Viewed 583 times
- Shalmeneser
Try to simplify everything.
- Capture du 2021-11-30 21-01-03.png (26 KiB) Viewed 575 times
- left leg back support pockets_SHALM.FCStd
- (78.32 KiB) Downloaded 6 times
There is a clone called Model-<<Something>> in the job, which you have to move, not the object you are working on.
