¿How to get global coordinates of feature?
Simbioz
Post by Simbioz »
So, what I am trying to achieve is setting the Y position of Cylinder004(label: Soporte3) equal to the Y position of a vertex of Box005(PlacaSoporte). Therefore, I edit the Y coordinate of Cylinder004 putting
Box005.Shape.Vertex3.Point.y
as an expression. This turns out to be 118mm, however the object is not in the position I expected. Hovering the mouse over the aforementioned vertex yields 340.5mm as the Y coordinate. I suspect 118mm is relative to the local coordinates and 340.5mm is relative to the global coordinates. What is the expression that gives the global coordinate of the Y component of the vertex?
Thanks.
OS: Arch Linux (sway/sway)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.7
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
sierra.FCStd
(236.48 KiB) Downloaded 41 times
Non native English speaker.
edwilliams16
Re: ¿How to get global coordinates of feature?
Post by edwilliams16 »
Simbioz
Post by Simbioz »
Is there a simpler way of getting the global coordinates of the object without having to mess with the python console?(which I know nothing about)
TheMarkster
Post by TheMarkster »
Simbioz wrote: Wed Dec 01, 2021 4:41 am Is there a simpler way of getting the global coordinates of the object without having to mess with the python console?(which I know nothing about)
None I am aware of. You can copy/paste this into the console after selecting your object and pressing Ctrl+Shift+P:
obj.addProperty("App::PropertyPlacement","GlobalPlacement").GlobalPlacement = obj.getGlobalPlacement()
(Untested)
It should give you a new property with the current global placement, but it will not automatically refresh. You would need to refresh it manually with:
obj.GlobalPlacement = obj.getGlobalPlacement()
openBrain
Post by openBrain »
Hover object with mouse pointer and read in the status bar.
You may consider to model this differently, by attaching things properly.
Besides: If you model in Part workbench, you should not use the PartDesign clones, use Draft clone instead.
Simbioz
Post by Simbioz »
openBrain wrote: Wed Dec 01, 2021 5:58 am
Yes, I tried this already, I memorize the string (because there seems no way to copy it) and write it in the expression box, getting;
 Result: Property 'sierra' not found in 'sierra.Part.Part002.Box005.Vertex3'
openBrain
Post by openBrain »
Simbioz wrote: Wed Dec 01, 2021 3:44 pm Yes, I tried this already, I memorize the string (because there seems no way to copy it) and write it in the expression box, getting;
AFAIK there is no way to use global coordinates in Expressions. You have to manually add all parents relative coordinates, but that will obviously break as soon as you move the object into other Part container.
Simbioz
Post by Simbioz »
chrisb wrote: Wed Dec 01, 2021 7:08 am You may consider to model this differently, by attaching things properly.
I am still not familiar with the attachment process or why it would be necessary/convenient to use it in this situation. I am gonna have a look at the wiki.
chrisb wrote: Wed Dec 01, 2021 7:08 am Besides: If you model in Part workbench, you should not use the PartDesign clones, use Draft clone instead.
Interesting, I read the respective wikis and I found no fundamental reason to use one over the other for my model. Why are you suggesting this?
Thanks
drmacro
Post by drmacro »
Simbioz wrote: Wed Dec 01, 2021 5:05 pm
Your model seems to be developed in a rather haphazard way. This may be the reason you need global coordinates.
Thanks
It is typical to recommend to new user to use either Part workbench or Part Design workbench exclusively.
Once the subtleties of each is experienced, then it is advisable to understand the rules required involved when mixing the two.
If you read this wiki page and have a look at the example of creating identical models with each workbench exclusively you may find some insight:
https://wiki.freecadweb.org/Part_and_PartDesign
