Hallo Zusammen,
Ihr wisst ja.... mal wieder eine Dummy Frage:
.... was hab ich nicht berücksichtigt, dass mir die Fehlermeldung: "part has multiple solids" angezeigt wird?
Ich hänge mal die Datei dran. Vermutl. nur was kleines und ich bin um jede Hilfe dankbar.
VG
Tobi
Part has multiple solids
- Arbeitstisch.FCStd
- (32.03 KiB) Downloaded 23 times
- multiple solids 2.JPG (44.53 KiB) Viewed 893 times
- Multiple Solids.JPG (28.32 KiB) Viewed 893 times
- Shalmeneser
Re: Part has multiple solids
Pad : reverse = true
If you pad with outside direction, there are 2 bodies (just touching themselves along edges).
Top!
thanks!
VG
Tobi
thanks!
VG
Tobi
- Shalmeneser
(In Help forum, use English. Deutsch forum is top-level.)
1) Do not sketch on face. You will meet Topological_naming_problem
2) Lines on the faces are just cosmetics ones. Try Refine=true in the ComboView Data of the last operation. This body is just ONE piece.
- Capture.PNG (6.48 KiB) Viewed 733 times
- Shalmeneser
More logically :
1) 1 big rectangle
2) 2 triangle holes (Sketcher_External + Sketcher_ToggleConstruction)
1) 1 big rectangle
- Arbeitstisch_SHALM.FCStd
- (25.5 KiB) Downloaded 18 times
Verschoben ins deutsche Forum.
