OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu-wayland)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.0
Hi all,
I've struggling a bit with BIM for a year now. I've successfully modeled my house a bit in rough, but now I want to do more detailed things and the workbenches confuse me.
Tutorials do not help me out, so I start to think my conceptual understanding of how to use the software is incorrect.
What I'd like to do:
- Create some parts (e.g. wooden beams)
- Connect them together (e.g. at a line or corner)
- Place new objects on this connected construction
Is this a proper use of BIM, or should I go with creating parts and using it more as an Assembly?
Things I've tried is:
- in BIM, adding new components referenced to an existing plane (of another component), does not allow re-use (?) of parts
- in Part Design create a new part, but how do I connect two of the same together?
I feel I'm either trying to use FC in a completely wrong way it was not intended for, or just have a conceptual misinterpretation of how I should approach this problem. The fact that I haven't found any tutorial or similar questions makes me lean to the former...
Connect "parts" in BIM?
- thomas-neemann
Re: Connect "parts" in BIM?
with the geometry in a bim process, in my opinion, you can do whatever you want if no attributes are required.
if attributes are required, in my opinion there is no way around coordinating with each new partner exactly how and which attributes are sent in the ifc file. e.g. for heat calculations, static proof, quantity determination, tga, etc.
I'm not sure if I understand what you mean.thomas-neemann wrote: ↑Thu Dec 02, 2021 5:47 pm
What do you mean by attributes? And partners?
I think one of my sub-questions is; How do I add parts from Part Design correctly in the BIM workbench and connect them together?
@yorik, the creator of the Arch and BIM workbench as well as one of the author of FreeCAD, has some beginner tutorials on suggested workflow to read e.g. https://wiki.freecadweb.org/Arch_tutorial
You may like to post our model, some sketch to illustrate better what do you like to do.
Moving this to Draft, Arch & BIM sub-forum for better exposure for more discussion hopefully
Thanks for moving it!paullee wrote: ↑Fri Dec 03, 2021 7:42 pm@yorik, the creator of the Arch and BIM workbench as well as one of the author of FreeCAD, has some beginner tutorials on suggested workflow to read e.g. https://wiki.freecadweb.org/Arch_tutorial
I've followed the the tutorial a while ago, but will revisit to see if I missed something.
Attached is a screenshot of my simple current try;
It contains two mirrored beams with cutouts that I want to interlace.
You created a beam.
Then you want to use that again at another position?
Try Draft.Clone, or App::Link
(You may like to 'contain' the PartDesign object in an Arch Object e.g. ArchStructure to make it a 'Arch/BIM' object - select the PartDesign object, click e.g. ArchStructure button
Not only use it again in another position, actually connecting these beams together by referencing their absolute position on selected points (or lines, or faces). It feels more like assembly.paullee wrote: ↑Fri Dec 03, 2021 8:35 pm You created a beam.
I probably can do that through a script, right? I realize FreeCAD is suddenly infinitely more powerful when interfacing through Python.
Edit: Will give creating ArchStructures a try!
Usually no need a script in most of examples users discussed here unless you have something very specialdasmodel wrote: ↑Fri Dec 03, 2021 10:08 pm Not only use it again in another position, actually connecting these beams together by referencing their absolute position on selected points (or lines, or faces). It feels more like assembly.
Would suggest you follow the workflow in the tutorial first, post your model for peoples to understand your thoughts.
Maybe, Draft Clone / make Links to your created beam, Draft Move to position the Clones / Links to desirable locations would do.
Good luck.
