Hi
How to draw a curved ramp? My first attempt with helix and boolean operators was quite a lot of work. Is there an easier way?
Regards
Curved ramp
Curved ramp
- CurvedRamp.FCStd
- (41.13 KiB) Downloaded 28 times
- thomas-neemann
Re: Curved ramp
Last edited by thomas-neemann on Thu Dec 02, 2021 12:03 pm, edited 1 time in total.
- papyblaise
Re: Curved ramp
you do a helix and cut it with a rectangle thruAll and symetric
- rampe.PNG (3.38 KiB) Viewed 1521 times
- rampe.FCStd
- (35.5 KiB) Downloaded 24 times
Re: Curved ramp
Fast example with blendcurves (yellow, Curves-wb) and Surface-wb (the ramp itself).
The blendcurves are attached to the cubes. Adjust blendcurves via data-tab.
Re: Curved ramp
Hello, greetings to the Community!
The example * .gif (very modular) modeled with "Part" can be done, obviously, with "Part Design", however we do it we can check the parameters using a spreadsheet and dynamically see the result.
- Curved ramp.FCStd
- (14.93 KiB) Downloaded 25 times
- Rampa_Curva_editable.gif (579.75 KiB) Viewed 1473 times
Re: Curved ramp
You see that it is not possible in a much easier way. In your model you shouldn't use a sketch in a body; move it out with the mouse and remove the body. That makes your model slightly simpler.
Re: Curved ramp
Hi
Thanks! Many solutions, will try them all to find the best one for me.
Regards
Regards
