Freecad collision detection
bambuko
Re: Freecad collision detection
Post by bambuko »
kwahoo wrote: Fri Dec 03, 2021 4:43 pm ...If this can be useful for anyone...
That's very interesting.
Is your gif running in a loop? if so how do you control it?
Which element/part/constraint of your assembly did you animate?
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
kwahoo
Post by kwahoo »
chrisb wrote: Fri Dec 03, 2021 4:46 pm Looks indeed very good. Can you provide the ffmpeg parameters?
There is a comment in the last line of the script:
ffmpeg -framerate 25 -i %00d.png -c:v libx264 -profile:v high -crf 20 -pix_fmt yuv420p output.mp4
bambuko wrote: Fri Dec 03, 2021 5:25 pm Is your gif running in a loop? if so how do you control it?
The script loops the animation, until I type
animation.stop()
but you can add if statement to stop animation after defined number of frames.
The script changes a single cell in the Spreadsheet
App.getDocument("fixedgear").Spreadsheet.set("A2", str(self.an))
and the Spreadsheet drives a Sketch in one of the parts. Other parts are constrained to that Sketch.
Thanks!
bambuko
Post by bambuko »
kwahoo wrote: Fri Dec 03, 2021 7:19 pm ...but you can add if statement to stop animation after defined number of frames...
Thank you,
So I guess you define the step, number of steps and stop it afterwards?
This way (as long as number of steps x step = 360 deg) you can create .gif that can run (smoothly) in a continuos loop.
kwahoo
Post by kwahoo »
bambuko wrote: Sat Dec 04, 2021 8:36 am So I guess you define the step, number of steps and stop it afterwards?
Number of steps or some other value that increments every step. I posted an example in this thread https://forum.freecadweb.org/viewtopic. ... 01#p541101
Reposting it here
import FreeCAD as App, FreeCADGui as Gui, Part, time
from PySide2 import QtGui,QtCore
class Animation(object):
    def __init__(self):
        App.Console.PrintMessage('Animation started\n')
        self.timer = QtCore.QTimer()
        QtCore.QObject.connect(self.timer, QtCore.SIGNAL("timeout()"), self.my_update)
        self.timer.start(100) #a step every 0.1s (100 ms)
        self.val = 0.0 #start value
        self.step = 1.0 #step value
        self.end = 360.0 #end value
    def my_update(self):
        App.ActiveDocument.Spreadsheet.set("A2", str(self.val)) #write value to A2 cell
        self.val = self.val + self.step #next value will be incremented by the step
        if self.val > self.end: #stop updating after 360
            self.timer.stop()
            App.Console.PrintMessage('Animation ended\n')
    def stop(self):
        self.timer.stop()
        App.Console.PrintMessage('Animation stopped\n')
animation = Animation()
bambuko
Post by bambuko »
kwahoo wrote: Sat Dec 04, 2021 8:56 am ....I posted an example in this thread https://forum.freecadweb.org/viewtopic. ... 01#p541101...
Thank you! That looks very useful.
I guess it can be used to drive anything (that could be useful to me) not just a cell value in a spreadsheet?
will have to experiment with it.... ;)
PS with apologies to OP for hijacking his post ;)
kwahoo
Post by kwahoo »
bambuko wrote: Sat Dec 04, 2021 11:51 am I guess it can be used to drive anything (that could be useful to me) not just a cell value in a spreadsheet?
You can do what you want with these values: change dims in sketches, constraints values in an assembly, dimensions of objects, transparency, colors, manipulate camera position...
TheMarkster
Post by TheMarkster »
Have a look at Animator macro, too.
bambuko
Post by bambuko »
TheMarkster wrote: Sat Dec 04, 2021 5:26 pm ...Animator macro...
Thank you,
I animate my assemblies by changing placement angle of one single part/body along selected axis (the rest of the assembly is constrained to this particular part/body) .
How would it handle the "solve constraints" command needed after every single step in my assembly?
I will try your macro on one of my test models.
bambuko
Post by bambuko »
kwahoo wrote: Sat Dec 04, 2021 3:26 pm ...You can do what you want with these values...
I guess I would have to add it?
