about "Draft" "Array tools" errors...help
my freecad version
FreeCAD_weekly-builds-26498-Win-Conda_vc14.x-x86_64
but before this version is no errors
FreeCAD_weekly-builds-26306-Win-Conda_vc14.x-x86_64
about "Draft" "Array tools" errors...please help
- xsuper9988
- TEST_ARRAY_ERROR.png (111.7 KiB) Viewed 1587 times
- TEST_ARRAY_ERROR.FCStd
- (8.28 KiB) Downloaded 29 times
- SLIDER_CGW25.FCStd
- (194.1 KiB) Downloaded 29 times
- TEST_ARRAY_ERROR.txt
- (447 Bytes) Downloaded 26 times
Re: about "Draft" "Array tools" errors...please help
If you upload more than one file, explain why and what to do with them. Don't let every single helper find out - even if it is simple, it takes some time:
SLIDER_CGW25.FCStd is a linked file, load it first.
TEST_ARRAY_ERROR.FCStd links the former.
Put your output in codetags instead of attaching a file. You can edit your post and fix this.
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
I have an intermediate version, and it works here:
OS: macOS 10.16
Version: 0.20.26375 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- xsuper9988
Trouble everyonechrisb wrote: ↑Fri Dec 03, 2021 7:59 am If you upload more than one file, explain why and what to do with them. Don't let every single helper find out - even if it is simple, it takes some time:
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
Will follow up next time
thank you very much
- xsuper9988
thank you very muchRoy_043 wrote: ↑Fri Dec 03, 2021 8:13 am The issue is related to this PR:
https://github.com/FreeCAD/FreeCAD/pull/5180
I'll have a look.
- xsuper9988
thank you very much
