PR above merged by @wmayer.
No I released https://github.com/FreeCAD/FreeCAD/pull/5232 that fixes the OP problem.
Bug: Wrong unit
Re: Bug: Wrong unit
While testing the recent locale specific PRs I found a small regression caused by PR 5232.
To test create a QuantitySpinBox with no unit:
When you scroll up/down or use the up/down arrow buttons the value doesn't change. It is stuck at 0.000 (or -0.000).
When setting a unit
it starts to work. But when removing the unit again
it is stuck again.
When only reverting the changes made to QuantitySpinBox::stepBy() and leave the rest it works normally again.
git commit b330a83273
ui=Gui.UiLoader()
w=ui.createWidget("Gui::QuantitySpinBox")
w.show()
When setting a unit
w.setProperty("unit", "m")
w.setProperty("unit", "")
Re: Bug: Wrong unit
Doing so you introduce a regression.wmayer wrote: ↑Sat Mar 26, 2022 5:22 pm When only reverting the changes made to QuantitySpinBox::stepBy() and leave the rest it works normally again.
Take any QuantitySpinbox with Unit preference being "Standard".
* Manually enter value of "9999 mm"
* Step up value -> "10 000 mm" -> OK
* Step up value again -> "11 mm" -> Oups
I can have a look at this in coming days if you want. If you have time or prefer to do it by yourself, please let me know.
Re: Bug: Wrong unit
Confirmed.Doing so you introduce a regression.
Go ahead, please. I will be busy to look at some of the other bugs.I can have a look at this in coming days if you want. If you have time or prefer to do it by yourself, please let me know.
