Bug: Wrong unit
perot
Bug: Wrong unit
Post by perot »
I found a situation where FreeCAD chooses default units inconsistently.
Load the file. Select the object, choose Part:Fillet. In the Fillet dialog, choose one of the edges, for instance "Edge9". Then at the bottom, in the "Radius:" field, enter "0.1" (no unit) and click OK. You find a nice fillet. Double clicking the fillet in the model tree re-opens the Fillet dialog, and you confirm that the radius has been accepted as "0.1mm".
Repeat the above, but instead of "0.1", enter "0.095". You'd expect it would choose "mm" as the default unit again, and you'd get almost the same fillet, now of radius 95µm. Instead, FreeCAD chooses "µm" as the default unit, and converts the entered value into 95nm (as you confirm by re-opening the Fillet dialog), which results in an invisibly tiny fillet.
I tried to think of a reason for this behaviour to be intended, but I cannot come up with any, so I figure this must be a bug.
Cheers Peter
OS: Windows 7 SP 1 (6.1)
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
problem.FCStd
(12.99 KiB) Downloaded 21 times
bambuko
Re: Bug: Wrong unit
Post by bambuko »
Have a look at this thread:
https://forum.freecadweb.org/viewtopic.php?f=3&t=52057
Are your units set to "Metric small parts & CNC" ?
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
perot
Re: Bug: Wrong unit
Post by perot »
bambuko wrote: Fri Dec 03, 2021 4:44 pm Have a look at this thread:
Nope, my units are "Standard (mm/kg/s/degree)".
I'll take a look at that thread ...
Cheers Peter
openBrain
Re: Bug: Wrong unit
Post by openBrain »
Do you have same thing if you use ',' (comma) instead of '.' (period) in your numbers?
Re: Bug: Wrong unit
Please add your FreeCAD infos. It works here correctly. I have the comma ',' as decimal separator.
OS: macOS 10.16
Version: 0.20.26375 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
Re: Bug: Wrong unit
openBrain wrote: Fri Dec 03, 2021 4:51 pm Do you have same thing if you use ',' (comma) instead of '.' (period) in your numbers?
If I do it vice versa and enter "0.95" it becomes 95mm (not nm).
perot
Re: Bug: Wrong unit
Post by perot »
As I understand that thread, it is about FreeCAD displaying the numbers in suitable units, vs. forcing it to always display numbers in the same unit. That behaviour is fine with me.
My (suspected) bug is about FreeCAD assuming the wrong unit when accepting user input.
Cheers Peter
thomas-neemann
Re: Bug: Wrong unit
Post by thomas-neemann »
perot wrote: Fri Dec 03, 2021 4:39 pm
what speaks against specifying the unit mm?
perot
Re: Bug: Wrong unit
Post by perot »
chrisb wrote: Fri Dec 03, 2021 4:54 pm
That does not make any sense either, I'd take it as another manifestation of the same bug.
Comma or decimal point does not make any difference for me. FreeCAD surprisingly accepts both, with the same wrong result.
Cheers Peter
openBrain
Re: Bug: Wrong unit
Post by openBrain »
perot wrote: Fri Dec 03, 2021 4:56 pm My (suspected) bug is about FreeCAD assuming the wrong unit when accepting user input.
When you reopen the dialog to enter 0.095, did you pay attention to already present unit? Did you really delete it?
