[Bug] Changing 3d view background color
HakanSeven12
Post by HakanSeven12 »
When I tried to change the background color freecad collapses every time.
reeCAD 0.19, Libs: 0.19R24291 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
connect failed: Böyle bir dosya ya da dizin yok
Cannot find icon: preferences-Import-export
(freecad:90873): Gtk-CRITICAL **: 00:25:45.672: _gtk_style_provider_private_get_settings: assertion 'GTK_IS_STYLE_PROVIDER_PRIVATE (provider)' failed
#0  /usr/lib/libc.so.6(+0x3cda0) [0x7ff2842f4da0]
#1  /usr/lib/libgtk-3.so.0(+0x1163dc) [0x7ff27d9183dc]
#2  /usr/lib/libgtk-3.so.0(+0x12e034) [0x7ff27d930034]
#3  /usr/lib/libgtk-3.so.0(+0x11ff15) [0x7ff27d921f15]
#4  /usr/lib/libgobject-2.0.so.0(g_type_create_instance+0x203) [0x7ff27d654833]
#5  /usr/lib/libgobject-2.0.so.0(+0x212f6) [0x7ff27d63c2f6]
#6  /usr/lib/libgobject-2.0.so.0(g_object_new_with_properties+0x2cd) [0x7ff27d63d32d]
#7  /usr/lib/libgobject-2.0.so.0(g_object_new+0xc2) [0x7ff27d63dd12]
#8  /usr/lib/libgtk-3.so.0(+0x329dcf) [0x7ff27db2bdcf]
#9  /usr/lib/libgobject-2.0.so.0(g_type_create_instance+0x203) [0x7ff27d654833]
#10  /usr/lib/libgobject-2.0.so.0(+0x212f6) [0x7ff27d63c2f6]
#11  /usr/lib/libgobject-2.0.so.0(g_object_new_valist+0x16b) [0x7ff27d63d78b]
#12  /usr/lib/libgobject-2.0.so.0(g_object_new+0x9a) [0x7ff27d63dcea]
#13  0x7ff27e00ac6c in QGtk3ColorDialogHelper::QGtk3ColorDialogHelper() from /usr/lib/qt/plugins/platformthemes/libqgnomeplatformtheme.so+0x5c
#14  0x7ff27e008827 in QGnomePlatformTheme::createPlatformDialogHelper(QPlatformTheme::DialogType) const from /usr/lib/qt/plugins/platformthemes/libqgnomeplatformtheme.so+0x47
#15  0x7ff285676586 in QDialogPrivate::platformHelper() const from /usr/lib/libQt5Widgets.so.5+0x96
#16  /usr/lib/libQt5Widgets.so.5(+0x370ff4) [0x7ff285672ff4]
#17  0x7ff286e8c082 in Gui::ColorButton::onChooseColor() from /usr/lib/freecad/lib/libFreeCADGui.so+0x62
#18  /usr/lib/libQt5Core.so.5(+0x2fa95b) [0x7ff2849af95b]
#19  0x7ff285556927 in QAbstractButton::clicked(bool) from /usr/lib/libQt5Widgets.so.5+0x47
#20  /usr/lib/libQt5Widgets.so.5(+0x254bd0) [0x7ff285556bd0]
#21  /usr/lib/libQt5Widgets.so.5(+0x256868) [0x7ff285558868]
#22  0x7ff285558a99 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) from /usr/lib/libQt5Widgets.so.5+0xf9
#23  0x7ff2854a0fce in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x20e
#24  0x7ff28545cff6 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x86
#25  0x7ff285464e59 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0xaa9
#26  0x7ff286a44af9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
#27  0x7ff2849781fa in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x13a
#28  0x7ff2854638ff in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /usr/lib/libQt5Widgets.so.5+0x1bf
#29  /usr/lib/libQt5Widgets.so.5(+0x1b8e98) [0x7ff2854bae98]
#30  /usr/lib/libQt5Widgets.so.5(+0x1bc215) [0x7ff2854be215]
#31  0x7ff28545cff6 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x86
#32  0x7ff286a44af9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
#33  0x7ff2849781fa in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x13a
#34  0x7ff284d58c50 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /usr/lib/libQt5Gui.so.5+0x6b0
#35  0x7ff284d2db15 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Gui.so.5+0xb5
#36  /usr/lib/libQt5XcbQpa.so.5(+0x63800) [0x7ff27ecc0800]
#37  /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x26c) [0x7ff2826cf4dc]
#38  /usr/lib/libglib-2.0.so.0(+0xa8799) [0x7ff282723799]
#39  /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7ff2826ccbc1]
#40  0x7ff2849d1b1a in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x6a
#41  0x7ff284976aab in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x12b
#42  0x7ff285677b0e in QDialog::exec() from /usr/lib/libQt5Widgets.so.5+0x20e
#43  0x7ff286aaea97 in StdCmdDlgPreferences::activated(int) from /usr/lib/freecad/lib/libFreeCADGui.so+0x37
#44  0x7ff286a79be1 in Gui::Command::invoke(int, Gui::Command::TriggerSource) from /usr/lib/freecad/lib/libFreeCADGui.so+0x371
#45  /usr/lib/libQt5Core.so.5(+0x2fa95b) [0x7ff2849af95b]
#46  0x7ff285456237 in QAction::triggered(bool) from /usr/lib/libQt5Widgets.so.5+0x47
#47  0x7ff285459060 in QAction::activate(QAction::ActionEvent) from /usr/lib/libQt5Widgets.so.5+0xb0
#48  /usr/lib/libQt5Widgets.so.5(+0x2e8733) [0x7ff2855ea733]
#49  /usr/lib/libQt5Widgets.so.5(+0x2f05c1) [0x7ff2855f25c1]
#50  0x7ff2854a0fce in QWidget::event(QEvent*) from /usr/lib/libQt5Widgets.so.5+0x20e
#51  0x7ff28545cff6 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x86
#52  0x7ff285464e59 in QApplication::notify(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0xaa9
#53  0x7ff286a44af9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
#54  0x7ff2849781fa in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x13a
#55  0x7ff2854638ff in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /usr/lib/libQt5Widgets.so.5+0x1bf
#56  /usr/lib/libQt5Widgets.so.5(+0x1b99b3) [0x7ff2854bb9b3]
#57  /usr/lib/libQt5Widgets.so.5(+0x1bc215) [0x7ff2854be215]
#58  0x7ff28545cff6 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /usr/lib/libQt5Widgets.so.5+0x86
#59  0x7ff286a44af9 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib/freecad/lib/libFreeCADGui.so+0x89
#60  0x7ff2849781fa in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /usr/lib/libQt5Core.so.5+0x13a
#61  0x7ff284d58c50 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /usr/lib/libQt5Gui.so.5+0x6b0
#62  0x7ff284d2db15 in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Gui.so.5+0xb5
#63  /usr/lib/libQt5XcbQpa.so.5(+0x63800) [0x7ff27ecc0800]
#64  /usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x26c) [0x7ff2826cf4dc]
#65  /usr/lib/libglib-2.0.so.0(+0xa8799) [0x7ff282723799]
#66  /usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7ff2826ccbc1]
#67  0x7ff2849d1b1a in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x6a
#68  0x7ff284976aab in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /usr/lib/libQt5Core.so.5+0x12b
#69  0x7ff28497f298 in QCoreApplication::exec() from /usr/lib/libQt5Core.so.5+0x98
#70  0x7ff28699686e in Gui::Application::runApplication() from /usr/lib/freecad/lib/libFreeCADGui.so+0x1b9e
#71  freecad(+0x4858) [0x559d34fdf858]
#72  /usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7ff2842dfb25]
#73  freecad(+0x4b8e) [0x559d34fdfb8e]
OS: Manjaro Linux (GNOME/gnome)
Version: 0.19.24291 (Git)
Branch: makepkg
Python version: 3.9.7
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Turkish/Turkey (tr_TR)
Last edited by HakanSeven12 on Tue Dec 07, 2021 12:26 pm, edited 2 times in total.
drmacro
Re: Changing 3d view background color
Post by drmacro »
Maybe a 0.19 issue, works fine here for 0.20
OS: Ubuntu 20.04.3 LTS (XFCE/ubuntustudio)
Version: 0.20.26555 (Git)
Hash: 67f8a4c61c19e7a69a43c4e11668eea1de5886b9
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
HakanSeven12
Re: Changing 3d view background color bug
I don't have this issue on windows too. But Manjaro has this bug.
drmacro
Post by drmacro »
Again seems ok here...
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.26441 (Git)
Hash: cf337394a16c42a4e65740b7dffa450e76bb5b6a
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
HakanSeven12
Re: [Bug] Changing 3d view background color
It looks like freecad collapses every time I try to open a color palette window. Is there any solution?
drmacro
Post by drmacro »
What is different about your version of Manjaro compared to mine where it works just fine...?
HakanSeven12
There is only two differences. I'm using gnome version and I'm using FreeCAD 0.19.
alu
Post by alu »
Hi Hakan,
I have the exact same error. I wanted to use the FreeCAD version from the official repo on Manjaro. Every time I want to change a color in the settings dialog, FreeCAD is crashing (terminates silently).
When I use the snap version of FreeCAD the color changing works as expected.
I think like you, that there's something missing in the version from the official repo. Where is the best place to report this? Is it here or in the Manjaro forum?
alu wrote: Tue Dec 21, 2021 10:45 amIs it here or in the Manjaro forum?
In the Manjaro forum.
TheMarkster
Post by TheMarkster »
Try opening a color pallet using the Colorize macro. I have a setting in there to not use the native color dialog. I don't know if this is an option in FreeCAD or not. I know there is an option for the native file dialogs.
