Spring renders incorrectly
NewJoker
Post by NewJoker »
I'm trying to create a conical spring. Here's what I do:
1) Create new body
2) Add helix primitive and adjust the parameters
3) Create a sketch of a profile for sweep
4) Use Part module Sweep
And here's what I get:
After exporting to step and opening in a different software the spring looks fine. So it seems to be some rendering issue. Do you know what's going on ?
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
I attached a FreeCAD file as well.
Spring fail.FCStd
(34.27 KiB) Downloaded 35 times
drmacro
Re: Spring renders incorrectly
Post by drmacro »
Seems ok if you don't mix Part and Part Design...
Snip macro screenshot-f36d5c.png (161.14 KiB) Viewed 2001 times
NewJoker
Post by NewJoker »
Thank you for the replies. I should switch to 0.20 to avoid problems like that in the future. But it would be good to eliminate this issue for the default rendering settings, if possible.
drmacro
Post by drmacro »
NewJoker wrote: Wed Dec 08, 2021 11:07 pm Thank you for the replies. I should switch to 0.20 to avoid problems like that in the future. But it would be good to eliminate this issue for the default rendering settings, if possible.
I think that is the issue; there is no default setting that works for all situations.
The rendering settings - Deviation and AngularDeflection - are a different topic. They seem to be currently a good compromise between quality and speed.
I don't know if changing the segment length has other undesired side effects, because we usually change it only if something goes wrong. Could be an interesting experiment though.
un1corn
Post by un1corn »
I too had this problem even with straight springs, it seems that version 19 does not react the same as previous versions, I have found that after defining the helix and shape to be swept it works OK using the adaptive helix tab in PD WB.
My request for help posted on December 3rd, found for myself eventually.
I was surprised that version 19 did not reach a stable version, I am neither a programmer or developer so maybe there is more to it than meets the eye.
NewJoker
Post by NewJoker »
Now I'm using 0.20 and I went back to this to see if I can make it work in this version without the need to change the modeling approach. Unfortunately, none of the options mentioned in this thread and the other one referenced by Shalmeneser works. I tried reducing the angular deflection and deviation, as well as adjusting the helix segment length but the spring is still rendered incorrectly. Is there anything else that can be done to eliminate this issue ? I think that it's time to report it on GitHub.
OS: Windows 10 (10.0)
Version: 0.20.27809 (Git)
Python 3.8.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
kisolre
Post by kisolre »
Using a SectionLength of 0.2 (1/5th) and the whole Helix object (instead of just the segments) works here:
Version: 0.20.28003 (Git)
Hash: 248946009c2c584d6cc7731d156de677eba2462d
Python 3.8.8, Qt 5.15.2, Coin 4.0.1, OCC 7.5.3
Spring fail_kiss.FCStd
(90.17 KiB) Downloaded 16 times
NewJoker
Post by NewJoker »
kisolre wrote: Sat Mar 12, 2022 9:26 am
Thanks. In addition to changing the segment length, I also had to redefine the sweep path so that it includes the whole helix. How did you select it ? I only managed to do it by editing the Spine setting of the existing Sweep and deleting the edges listed next to the Helix. Is there a way to select the whole helix while defining a new Sweep ? When I click the Sweep Path button, I have to pick all the edges one by one. Box selection can help but maybe it's also possible to select the whole Helix object at once in some other way that I missed.
