Another Sketch which seems to have a broken face
Hi there,
I have a sketch with only one "island", the whole structure is closed but yet it fails to extrude into 3D with "failed to validate broken face".
Here is my file: https://ufile.io/x3tu298m
I can not find the mistake, could anybody please help me out?
Thanks in advance
Thanks in advance
Re: Another Sketch which seems to have a broken face
Hi and welcome to the forum!
The Validate Sketch tool helps to find open vertices, but what is worse, your sketch is badly constrained: repitition of dimensions, missing coiincidences, dimensions instead if geometric constraints. I didn't fix all of these, only what it needs to pad.
And, by taking advantage of symmetry, there is 1/4 of the work...
- Shalmeneser
- Shalmeneser
- Capture du 2021-12-07 21-18-43.png (28.04 KiB) Viewed 643 times
- test_SHALM.FCStd
- (24.74 KiB) Downloaded 10 times
- Capture du 2021-12-07 21-19-30.png (64.87 KiB) Viewed 643 times
Sorry-
- test_cb.FCStd
- (20.53 KiB) Downloaded 8 times
Impressive! If the 23.3 and 23.31 should indeed be equal, then you could even save one of these by simple usage of a tangent constraint.
- Shalmeneser
No chance !
My main problemn is not understanding the logic of the original sketch.
- Capture du 2021-12-07 22-22-01.png (11.2 KiB) Viewed 589 times
No, like that:
- SnipScreenshot-5e98a1.png (22.96 KiB) Viewed 554 times
- Shalmeneser
The tangential symbol was so discret that I did not find the solution at the beginning.
- Capture du 2021-12-07 23-51-46.png (27.91 KiB) Viewed 526 times
