Loft of ShapeBinder fails in Part Design but works in Part WB
drmacro
Post by drmacro »
In the attached file if you attempt to Part Design Loft the ShapeBinders in Body001 it fails with No valid sub element error.
But, Part Loft with the ShapeBinders works... (other than the out of scope warning)
Snip macro screenshot-08c3bd.png (112.37 KiB) Viewed 869 times
noloft-mac.FCStd
(22.87 KiB) Downloaded 10 times
TheMarkster
Re: Loft of ShapeBinder fails in Part Design but works in Part WB
Post by TheMarkster »
A workaround: edit the Profile property so it says instead of ShapeBinder, ShapeBinder.Wire1 (seems to work).
Snip macro screenshot-98bc35.png (82.71 KiB) Viewed 818 times
drmacro
Post by drmacro »
That makes sense.
But a bit inconsistent...you don't need the change that to Pad. ;)
Yes, I realize Pad is not Loft. :mrgreen:
:lol:
TheMarkster
Pad was probably updated to work with shapebinders, but not Loft.
drmacro
Post by drmacro »
TheMarkster wrote: Wed Dec 08, 2021 12:27 am Pad was probably updated to work with shapebinders, but not Loft.
Does it make sense to enter into tracker?
drmacro wrote: Wed Dec 08, 2021 1:06 pm Does it make sense to enter into tracker?
Yes please. It would be convenient. It would be consistent.
drmacro
Post by drmacro »
chrisb wrote: Wed Dec 08, 2021 4:05 pm
Done.
issue #0004799
