Help offset B-spline
I'm trying to offset a B-spline in a sketch (see image) in order to close it and Pad the shape. The remainder of my part has been built using PartDesign (so I'm trying to avoid the Part offset tool). Is this possible? I have attempted using the Draft workbench offset tool and cannot get it to work.
Thanks!
FreeCAD .19
Windows OSX
Thanks!
FreeCAD .19
Windows OSX
- Capture.PNG (165.64 KiB) Viewed 1317 times
- thomas-neemann
Re: Help offset B-spline
is that a solution for you?
https://www.youtube.com/watch?v=uE9D0Mc2A1Y
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26554 (Git) AppImage
Branch: (HEAD detached at 817c14b)
Hash: 817c14b16af681b06aec7d8c79f744c7a88fa3c3
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Thomas,
Thanks for the reply! That absolutely is a solution and the end geometry I'm looking for, but I'm trying to avoid using the part bench as the rest of the model was built in part design (and I typically run into issues when I attempt to combine the two...). So I was seeing if there's another way to accomplish that same geometry, but without the part workbench?
It is not illegal, you just have to do it right, and starting in one workbench and continuing in another is manageable:
- Create your B-spline outside of a PartDesign body in Sketcher workbench
- create the offset
- create a PartDesign body
- select the offset object and create a ShapeBinder.
Part WB is "FreeCAD core library" as it is the "direct interface" with OCCT engine, so ho harm could happen if you use some "low level" thing in "high level" WB like PartDesign.
each PartDesign Object at the very end is using "Part" in a way or another.
The point is "how you are mixing things", maybe some actions are wrong.
Regards
Carlo D.
- Various other stuffs.
- thomas-neemann
very good info. Can i look that up somewhere?
In what sense:
https://wiki.freecadweb.org/Topological_data_scripting
https://wiki.freecadweb.org/Part_and_PartDesign
Last sentence seem to say that.
But, sadly there is not PartDesign scripting around, let me try to put together something.
But as a proof of concept you could see this links, from the PartDesign source code:
https://github.com/FreeCAD/FreeCAD/blob ... ts/Gear.py
From a simple:
print(dir(PartDesign))
For now using some test code in sources I've put together something :
"""partdesign_example.py
This code was written as an sample code
Author: Carlo Dormeletti
Copyright: 2021
Licence: CC BY-NC-ND 4.0 IT
import os
import os.path
import math
import FreeCAD
from FreeCAD import Placement, Rotation, Vector
import Part
import Path
import Draft
import PartDesign
DOC_NAME = "partdesign_example"
DOC = FreeCAD.activeDocument()
def clear_doc():
Clear the active document deleting all the objects
for obj in DOC.Objects:
try:
DOC.removeObject(obj.Name)
except Exception:
pass
def create_doc(doc_name):
obj = FreeCAD.newDocument(doc_name)
return obj.Name
def setview():
"""Rearrange View"""
DOC.recompute()
VIEW.viewAxometric()
VIEW.setAxisCross(True)
VIEW.fitAll()
print(DOC)
if DOC is None:
obj = create_doc(DOC_NAME)
FreeCAD.setActiveDocument(obj)
VIEW = FreeCAD.Gui.ActiveDocument.ActiveView
else:
if DOC.Name != DOC_NAME:
else:
clear_doc()
EPS = 0.10
EPS_C = EPS * -0.5
VZOR = Vector(0,0,0)
ROT0 = Rotation(0, 0, 0)
body = DOC.addObject('PartDesign::Body','Body')
box = DOC.addObject('PartDesign::AdditiveBox','Box')
body.addObject(box)
box.Length=10.00
box.Width=10.00
box.Height=10.00
DOC.recompute()
DatumPlane = DOC.addObject('PartDesign::Plane','DatumPlane')
DatumPlane.Support = [(DOC.YZ_Plane,'')]
DatumPlane.MapMode = 'FlatFace'
body.addObject(DatumPlane)
DOC.recompute()
DatumLine = DOC.addObject('PartDesign::Line','DatumLine')
DatumLine.Support = [(DOC.X_Axis,'')]
DatumLine.MapMode = 'TwoPointLine'
body.addObject(DatumLine)
DOC.recompute()
draft = DOC.addObject("PartDesign::Draft","Draft")
# Draft.Base needs to be top face
faces = box.Shape.Faces
# Grab the two faces with Z-normals and find the higher one
ZFaceIndexes = [i for i in range(len(faces)) if faces[i].Surface.Axis == Vector(0,0,1)]
if faces[ZFaceIndexes[0]].CenterOfMass.z > faces[ZFaceIndexes[1]].CenterOfMass.z:
TopFaceIndex = ZFaceIndexes[0]
else:
TopFaceIndex = ZFaceIndexes[1]
draft.Base = (box, ["Face"+str(TopFaceIndex+1)])
draft.NeutralPlane = (DatumPlane, [''])
draft.PullDirection = (DatumLine, [''])
draft.Angle = 45.0
draft.Reversed = 1
body.addObject(draft)
DOC.recompute()
if 'Invalid' in draft.State:
draft.Reversed = 0
DOC.recompute()
setview()
print("--- done ---")
Not very constructive as this is simple "/PartDesign/PartDesignTests/TestDraft.py" (badly) transformed as a standalone script.
Regards
Carlo D.
- thomas-neemann
thank you carlo. this is very helpful at the moment
Greetings Thomas
Thanks everyone for the help! I'll plan on using the part WB to offset in my part design with shapebinders. Much appreciation to everyone who contributed anwers.
