You messed up your file by switching between versions...yes, that must be corrected.
Errors in the workbench sketcher
Re: Errors in the workbench sketcher
Hi memfis, greetings to the community
.... attached your file that contains two Sketches, in one (the original one) the constraint that causes the redundancy signal / error has been deactivated, the other full constrained.
I recommend reviewing the constraints trying to reduce them by optimizing them and, where possible, prefer geometric constraints to dimensional ones.
- error_2.FCStd
- (20.46 KiB) Downloaded 12 times
As pointed out before: you can open old files in new versions, but not vice versa. Word documents are completely independent from this, but show the same behaviour - try opening a docx in a Word on Win95.memfis wrote: ↑Thu Dec 09, 2021 8:44 am Colleagues, you are diligently deflecting the question. The essence of the problem = inadequate behavior of the solver, which needs refactoring.
The sub-questions are.
1. There are many FC assemblies. Most of them are branches with upgrades of separate parts, like Path, topo nam..., etc. What a way backward compatibility.... You do require that the doc file must open adequately in at least any Word of at least one major version, don't you?
No, you havent. You have shown us a sketch with errors, which doesn't prove, that the solver has produced them. The following still holds:2. I have clearly demonstrated that there is a problem.
