Problems with Pad when constructing girder bridge deck
PeterSD
Re: Problems with Pad when constructing girder bridge deck
Post by PeterSD »
PeterSD wrote: Fri Jan 07, 2022 1:06 am
chrisb wrote: Fri Jan 07, 2022 12:22 am Perhaps this helps:
Whenever you cross a line, you switch from outside to inside or vice versa. If this is not possible, then a sketch cannot be padded.
Example:
Let's assume this sketch, you come from the left border and walk to the right
- You start at the outside
- you pass the first vertical line, no you are inside; this will be solid
- you pass the circle, now you are outside, this will be a hole with no material
- you pass the other side of the circle, you are inside again
- you pass the left vertical line of the inner rectangle and are outside again
- pass the right vertical line of the inner rectangle and are inside again
- pass the rightmost vertical line and you are outside again
This is what the pad will look like:
Now consider your sketch, look at the left lower line: Which side is inside, and which is outside?
Thanks Chris
I have reviewed what was successful in the past and created a new file.
Note I have deleted and replaced this file. The file below is the latest version and relevant to the description and images below. Apologies all
Deck Rev 4._b Reduced width.FCStd
(56.08 KiB) Downloaded 8 times
What I have done here in Sketch 003 is to select to long edge of the top face the Bridge Deck. This revealed Start and end connection points and created an external line between these two points (Line 10 in the Elements).
I then created the sketch again; Line 1 connects the sketch to the point at the outer edge of the deck and then the lines are sequentially numbered clockwise around the sketch.
Deck Rev 4b Re-drawn Sketch003.PNG (135.07 KiB) Viewed 1208 times
I then tried to Pad the sketch
Deck Rev 4b Re-drawn Pad attempt.PNG (44.95 KiB) Viewed 1208 times
When I returned to the sketch Line 1 was not visible.
Kind Regards
Peter
bambuko
Post by bambuko »
It's the same problem I have pointed to you in my previous email in this topic (plus one more)
You have one line too many and your sketch is in free air with no connection to the rest of the body:
Screenshot from 2022-01-07 12.56.18.png (35.59 KiB) Viewed 1189 times
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
PeterSD
Post by PeterSD »
bambuko wrote: Fri Jan 07, 2022 12:58 pm It's the same problem I have pointed to you in my previous email in this topic (plus one more)
Thanks for your reply. Did you see my latest reply at 12.38? I created a new issue number for it and the Document has a download link.
Kind regards
Peter
bambuko
Post by bambuko »
PeterSD wrote: Fri Jan 07, 2022 1:39 pm Thanks for your reply. Did you see my latest reply at 12.38?
12:35 ?
that is the one I am commenting on....
PeterSD
Post by PeterSD »
That is very strange. I was not able to see a pad result and I had been very careful to check the number of lines in the sketch. There are certainly no extras and one that is listed but cannot see it. It looks like version 4a to me.
bambuko
Post by bambuko »
It's the one thsa you can see (one of the red arrows is pointing to it) is surplus.
Plus, as I have said look at the 3d view I have attached (see second arrow) why is this face wonky?
PeterSD
Post by PeterSD »
bambuko wrote: Fri Jan 07, 2022 2:22 pm It's the one thsa you can see (one of the red arrows is pointing to it) is surplus.
It looks my it is my error :oops: The file I posted was Before the changes I described. I shall delete this file and upload the relevant file. Sorry.
(56.08 KiB) Downloaded 18 times
I am in the middle of house repairs and in my rush made this mistake. I am sorry if I have wasted your (and others) time.
bambuko
Post by bambuko »
PeterSD wrote: Fri Jan 07, 2022 3:34 pm ...I shall delete this file and upload the relevant file...
I am confused :roll:
so what is the file you have attached in this message???? (Deck Rev 4._b Reduced width.FCStd )
PeterSD
Post by PeterSD »
bambuko wrote: Fri Jan 07, 2022 3:44 pm
It is the correct file which i should have posted, not the one you all received in my earlier post. I have done the same in the earlier post and explained the issue I had with the earlier posting. I am glad you posted your comments as it was only ten that I had realised MY mistake. Apologies again.
bambuko
Post by bambuko »
Perhaps if you have said:
I have (rather than I shall) attached corrected version in this post (and renamed it rather than leaving exactly the same name ...)
there would have been less confusion ;)
Anyway, I have opened your file and both of my previous posts stand. You still have one dodgy/un-necessary line,
guess which one is it? (I have red arrowed it in both of my previous posts)
You can easily correct it, resulting in:
Deck(bambuko).FCStd
(74.15 KiB) Downloaded 11 times
Is that what you are after?
