Problems with Pad when constructing girder bridge deck
OS: Windows 10 Version 2004
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I am new to this.
I have constructed the base of the bridge as a Part.
I have then added the girders and padded them below the base without problem.
I have started the side walls and padded them to the to the top of the base again no problems.
I have added the top to the walls (3mm overhang both sided of the wall). This is where I have a problem with padding. I cannot find a way of attaching the start point of the pad to the top of the wall. It appears at the base, and when I increase the height, the overhangs rise until they obscure the walls above. Further increasing lifts the walls higher.
I have tried all types in the Pad drop down and failed.
Can anyone please help me?
Thank you
Kind regards
Peter
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I am new to this.
Thank you
Kind regards
Peter
Re: Problems with Pad when constructing girder bridge deck
You need to position the sketch you use to make the pad. There is an attachment offset property for this purpose, assuming it is attached to the xy plane. Now that your first post is approved you may attach your model for further investigation. Easiest way is to drag/drop onto the text field where you type in your post.
Can you link an image of the desired final result? We may suggest a different way of modeling this, e.g. by modeling a section or using a linear pattern for the girders.
Thank you for my approval and your comments.TheMarkster wrote: ↑Sat Dec 11, 2021 5:37 am You need to position the sketch you use to make the pad. There is an attachment offset property for this purpose, assuming it is attached to the xy plane. Now that your first post is approved you may attach your model for further investigation. Easiest way is to drag/drop onto the text field where you type in your post.
I am not sure how to 'drag and dop' I carried out the process and it did not seem to work.
I selected the sketcher item which produced the screen shot I made. Enabled clicked the Part and returned to the sketch which resulted in the image below.
Kind Regards
Peter
Thank you for your reply. Please see my attached image.
The image is similar to what T am aiming at but the the girders under the bridge need to be Jack Arch and I wanted the deck to be longer and wider.
Kind Regards
Peter
- papyblaise
just by seeing the 2 images, I think we have to make the Pad upwards so click the "invers" check mark
You can upload your FreeCAD file, so that we see what you have done so far.
I would start with something like this:
Multiply the girder with a liinear pattern. Set Length with an expression:
Sketch.Constraints.width - Sketch001.Constraints.girderWidth This has the advantage that you can very easily adapt the number of girders.
You could use a mirror here too, but that may be overkill. Next could be one single girder, with the previous sketch for external references:
Pad it using an expression (Pad.Length) to the same length as the previousMultiply the girder with a liinear pattern. Set Length with an expression:
- girderBridge.FCStd
- (27.73 KiB) Downloaded 23 times
Thank you chrisb and papyblaise for your replies. I am sorry I have not responded earlier but I am busy at the moment but will read your replies more thoroughly later and reply more fully later.
I set my email settings to be informed when replies are made to this thread but have received no emails for your posts. I shall have to re-check my settings - probabbly did something wrong
Kind regards
Peter
Kind regards
Peter
Thank you chrisb and papyblaise for your replies. I have now gone through your comments, downloaded your GirderBridge attachment file and the Sketcher Guide (thanks Chris). I have a lot to learn . Not surprising at all. All my learning has been done wading through hours of YouTube tutorials and string things together from this source.
I have managed to rduce the size of the photo ( which does appear in my earlier post but will give you a better idea of what I am targeting ). Please excuse the poor print quality of the 3D print. I bought my first 3D printer a couple of weeks ago and have had to familiarise myself with it. I think that I shall have to spend the next couple of days reading through things and then rebuilding my FreeCAD document and shall publish the results on this thread.
Once again, many thanks for your support.
Kind regards
Peter
Kind regards
Peter
