Can't use named constraints in 0.20 202112202219
If I create a rectangle in Sketcher and name a horizontal constraint for one side SideLength I get an error box appear saying No attribute named 'SideLength' and if I try to use it in a formula for the width of the rectangle it isn't recognised. I have to use Constraints[10] instead.
If I go back into that formula to edit it, it is changed to ".Constraints.SideLength" and again I see "No attribute named 'SideLength'"
Report view shows:
14:46:21 <Exception> ObjectIdentifier.cpp(622): No attribute named 'SideLength'
14:46:25 <Exception> ObjectIdentifier.cpp(622): No attribute named 'SideLength'
14:47:25 <Exception> ObjectIdentifier.cpp(622): No attribute named 'SideLength'
Report view shows:
Re: Can't use named constraints in 0.20 202112202219
Maybe with a file it would be easy to reproduce the behaviour and see if it is an error.
In case of a reserved file. Could you put together a Minimal Working Example file that produce the behaviour.
I deliberately not use "error" as maybe it is an expected behaviour due to some missing things or other quirks.
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
In the attached file, if I try to use a formula based on the length (SideLong) to constrain the width with Constraints.SideLong. I get "No attribute named 'SideLong', but Constraints[10] works.onekk wrote: ↑Tue Dec 21, 2021 4:45 pm Maybe with a file it would be easy to reproduce the behaviour and see if it is an error.
Regards
Carlo D.
Don't know if it is related, but in data view of the sketch The constraint is called Side Long.
- Screenshot_20211221_165346.png (27.94 KiB) Viewed 2498 times
Confirmed behaviour in build with today's source.
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26720 (Git)
Hash: 283b0a63824fd33b4f5a79c42e3f9ba7d0bd342b
Python version: 3.7.3
Qt version: 5.11.3
Qt version: 5.11.3
All I can add, is it definitely worked with Git revision 0.20.26683, hash acfde1a4b655cee307e3a8fc0066ca5c1dc2fdc9. Looks like some Git Bisecting is required as unless I'm completely blind (quite possible) I don't see an obvious candidate for the regression. If no-one's pinned it down by tomorrow morning UK time I'll have a crack at it.
chennes is working on the expressions.
A side nite if you active Python Console and modify Constraints Side Long what is appearing.
It could be that simply Side_Long is became the New Name.
In many places FreeCAD translate space and - and other characters to _ (underscore) so maybe something is changed in exposition of "variable names".
It is a rough guess but trying is not si difficult.
As someone that has deep knowledge of FreeCAD internals has told you that @chennes is working on it maybe us only a temporary regression due maybe to some "Work in Progress" in some methods.
Regards
Regards
One further issue of note. If I rename the original name from SideLong to something else, I get an error saying "No attribute named '...'" and where I have used Constraints[10] in the formula for the width is replaced by this new name and also says "No attribute named '...'".
Does this help at all?onekk wrote: ↑Tue Dec 21, 2021 8:39 pm A side nite if you active Python Console and modify Constraints Side Long what is appearing.
Regards
Python 3.9.9 (main, Nov 20 2021, 00:05:03)
[GCC 10.3.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
MRU="0"
with open('/usr/share/freecad-daily/Mod/Start/StartPage/LoadMRU.py') as file:
exec(file.read())
FreeCAD.openDocument('/home/mfraser/Pictures/FreeCAD/Rectangle Constraints.FCStd')
# App.setActiveDocument("Rectangle_Constraints")
# App.ActiveDocument=App.getDocument("Rectangle_Constraints")
# Gui.ActiveDocument=Gui.getDocument("Rectangle_Constraints")
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.')
# Gui.Selection.clearSelection()
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Edge2',3.17461,29.3883,0)
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Edge2',20,29.3883,0)
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.',20,29.3883,0)
ActiveSketch = App.getDocument('Rectangle_Constraints').getObject('Sketch')
tv = Show.TempoVis(App.ActiveDocument, tag= ActiveSketch.ViewObject.TypeId)
ActiveSketch.ViewObject.TempoVis = tv
if ActiveSketch.ViewObject.EditingWorkbench:
tv.activateWorkbench(ActiveSketch.ViewObject.EditingWorkbench)
if ActiveSketch.ViewObject.HideDependent:
tv.hide(tv.get_all_dependent(App.getDocument('Rectangle_Constraints').getObject('Body'), 'Sketch.'))
if ActiveSketch.ViewObject.ShowSupport:
tv.show([ref[0] for ref in ActiveSketch.Support if not ref[0].isDerivedFrom("PartDesign::Plane")])
if ActiveSketch.ViewObject.ShowLinks:
tv.show([ref[0] for ref in ActiveSketch.ExternalGeometry])
tv.sketchClipPlane(ActiveSketch, ActiveSketch.ViewObject.SectionView)
tv.hide(ActiveSketch)
del(tv)
del(ActiveSketch)
import PartDesignGui
if ActiveSketch.ViewObject.RestoreCamera:
ActiveSketch.ViewObject.TempoVis.saveCamera()
if ActiveSketch.ViewObject.ForceOrtho:
ActiveSketch.ViewObject.Document.ActiveView.setCameraType('Orthographic')
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Constraint11',4.60317,36.0317,0.009,False)
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Edge1',50,-6.19048,0.008,False)
# Gui.Selection.removeSelection('Rectangle_Constraints','Body','Sketch.Edge1')
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Edge1',50,-2.53968,0.008,False)
### Begin command Sketcher_ConstrainDistanceY
App.getDocument('Rectangle_Constraints').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',0,1,0,2,58.776592))
App.getDocument('Rectangle_Constraints').Sketch.setExpression('Constraints[11]', u'Constraints[10] / 2')
### End command Sketcher_ConstrainDistanceY
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Constraint11',3.49207,32.0635,0.009,False)
App.getDocument('Rectangle_Constraints').getObject('Sketch').setDatum(10,App.Units.Quantity('100.000000 mm'))
App.getDocument('Rectangle_Constraints').getObject('Sketch').renameConstraint(10, u'SideLongNew')
# Gui.Selection.addSelection('Rectangle_Constraints','Body','Sketch.Constraint12',43.1746,-3.65079,0.009,False)
Put the Python code in code tags for improved readability. You can for further improvement copy only the code, without the leading ">>>".
