Can't use named constraints in 0.20 202112202219
TheMarkster
Re: Can't use named constraints in 0.20 202112202219
Post by TheMarkster »
Interestingly, the Animator macro is able to find the named constraints and animate them via python.
mfraz74
Post by mfraz74 »
chrisb wrote: Tue Dec 21, 2021 11:12 pm Put the Python code in code tags for improved readability. You can for further improvement copy only the code, without the leading ">>>".
Edited.
Syres
Post by Syres »
As promised I carried out the Git Bisect work and determined the regression was caused by git commit 2db73c0. I'm presently recompiling the very latest master to ensure the issue is still present, I'm struggling to understand how it would be fixed without changing the ObjectIdentifier.cpp but C++ is by no means my strong point.
mfraz74 wrote: Wed Dec 22, 2021 7:41 am Edited.
Thanks! To be clear: You don't have to remove the prefixes manually, if you use "Copy command" in the Python console's context menu.
Syres
Post by Syres »
As I assumed updating to the latest master hasn't fixed the issue.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.26761 (Git)
Hash: b0fc0ab0f4cfea326e047ac3166426e98d5e115f
Python version: 3.6.9
Qt version: 5.9.5
wmayer wrote: ping
Sorry to trouble you Werner, but could you please have a look at the report at the start of this topic with relation to git commit 2db73c0
Is it a real regression or has this shone a light on something else being incorrect?
realthunder
Post by realthunder »
I have submitted a PR for this.
Try Assembly3 with my custom build of FreeCAD at here.
Syres
Post by Syres »
Thanks @realthunder
Founder
Post by wmayer »
Syres wrote: Wed Dec 22, 2021 9:46 am Sorry to trouble you Werner, but could you please have a look at the report at the start of this topic with relation to git commit 2db73c0
Sorry for the regression and thanks for the fix! :oops:
Recently we have seen this one crash reported by chrisb where chennes has found the reason for and provided a fix: git commit b1beadd2e95b442
Nobody of the Linux testers could reproduce the crash because when assigning a null pointer to a std::string it throws an exception (a sub-type of std::exception) instead of causing a segmentation fault. After studying the error analysis I could reproduce the problem and also realized why the exception didn't show up. The calling instance used a catch(...) block that silently suppressed any kind of exception without reporting it. This makes it nearly impossible to find possible bugs inside the invoked functions in a try/catch(...) block.
In general, catch(...) blocks must be used with care because using them just out of laziness they harm rather than help.
Before committing my change I have checked the commit when the catch(...) has been added if there is an explanation for it. Because I didn't find any hint and neither by doing some simple tests nor by running the unit tests it entered the catch(...) block I decided to remove it.
After applying the PR we also have to write a unit test to avoid such a regression in the future.
Founder
Post by wmayer »
This is a short example that can be used for the unit tests:
doc = App.newDocument()
sketch = doc.addObject('Sketcher::SketchObject','Sketch')
geoList = []
geoList.append(Part.LineSegment(App.Vector(0,5,0),App.Vector(5,5,0)))
geoList.append(Part.LineSegment(App.Vector(5,5,0),App.Vector(5,0,0)))
geoList.append(Part.LineSegment(App.Vector(5,0,0),App.Vector(0,0,0)))
geoList.append(Part.LineSegment(App.Vector(0,0,0),App.Vector(0,5,0)))
sketch.addGeometry(geoList,False)
conList = []
conList.append(Sketcher.Constraint('Coincident',0,2,1,1))
conList.append(Sketcher.Constraint('Coincident',1,2,2,1))
conList.append(Sketcher.Constraint('Coincident',2,2,3,1))
conList.append(Sketcher.Constraint('Coincident',3,2,0,1))
conList.append(Sketcher.Constraint('Horizontal',0))
conList.append(Sketcher.Constraint('Horizontal',2))
conList.append(Sketcher.Constraint('Vertical',1))
conList.append(Sketcher.Constraint('Vertical',3))
sketch.addConstraint(conList)
del geoList, conList
length = sketch.addConstraint(Sketcher.Constraint('Distance',0,6.0))
height = sketch.addConstraint(Sketcher.Constraint('Distance',3,5.0))
sketch.renameConstraint(length, u'Length')
sketch.setExpression('Constraints[{}]'.format(height), u'.Constraints.Length')
git commit 53f24f4bc2
drmacro
Post by drmacro »
It doesn't appear to work in this build, has it been merged?
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.26762 (Git)
Hash: 1653d26ffa0b35d57fc3325c18bf5b7bad515703
Python version: 3.7.3
Qt version: 5.11.3
