Not yet but will do it now...It doesn't appear to work in this build, has it been merged?
Can't use named constraints in 0.20 202112202219
Re: Can't use named constraints in 0.20 202112202219
How do I get the version with the implemented fix, if I'm using conda on Windows? There are new packages for Linux and OSX, but the newest Windows package is almost one month old (and has the bug).
- adrianinsaval
switch to LP builds... looo has said the windows builds on conda have been failing so you would have to wait until that's fixed if you want to stay using conda.
The Windows Conda build has a fault and people are working (voluntarily) to try to fix it. @uwestoehr mentioned in another thread that there will be a LibPack build available later tonight. You are welcome to start compiling yourself as I did but as a long time Windows user I took IMHO the easy route and dual booted a Linux partition. I compile on Linux for testing only, I still model on Windows for real work.
Here is a fresh Windows build: https://github.com/donovaly/FreeCADInst ... 0.20r27095
Sorry, this build was broken, here is a new and working one:uwestoehr wrote: ↑Tue Jan 18, 2022 11:13 pm Here is a fresh Windows build: https://github.com/donovaly/FreeCADInst ... 0.20r27095
https://github.com/donovaly/FreeCADInst ... 0.20r27129
