Corner appears cut
Corner appears cut
for a long time I've been puzzled as to why one corner of even very simple model such as cuboid always appears cut when I zoom on it:
I can even select this artificial face but it disappears after exporting to STEP file. Do you know what causes this distortion and if it can be fixed somehow ?
This happens in both 0.19 and 0.20 but here's my FreeCAD info for the former:
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Polish/Poland (pl_PL)
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Re: Corner appears cut
It's always easier if there is a FreeCAD file to examine?
otherwise it's guesswork?
(although I am sure ubergeeks here will know the answer just from attached picture)
Sure, I can provide the exemplary file. Here's a simple model of a cuboid that has this issue:
- adrianinsaval
Long existing visual glitch in FreeCAD, no idea what causes it but your model geometry is not affected, it's a rendering issue
- Shalmeneser
Part_CheckGeometry :
Checked object: Corner_distortion.Pad (Pad):
Shape type: Solid
Vertices: 8
Edges: 12
Wires: 6
Faces: 6
Shells: 1
Solids: 1
Nothing unusual. Just visual distorsion imho.
Shape type: Solid
Vertices: 8
Edges: 12
Wires: 6
Faces: 6
Shells: 1
Solids: 1
How do you pick/select a vertex on affected corner? (I haven't managed so far...)
later edit: you can actually select affected vertex by zooming far out
Problem disappears if you shorten the pad from original 500mm to 330mm (or less).
Anything above 330 shows the "cut corner"
Why this one corner, but no others?
BTW, it's not just 0.19 and 0.20 - I have the same problem in Link branch
All right, thanks. I assumed that it’s not harmful to the model (apart from the fact that this corner can’t be selected) but I wondered if you know what causes it and if it can be fixed. Does it happen for everyone or only for some users ? Maybe specific hardware or OS configurations are affected by this glitch.
- Shalmeneser
Same visualization problem
OS: Linux Mint 20.2 (MATE/mate)
Version: 0.20.26683 (Git) AppImage
Branch: (HEAD detached at 0388fbc)
Hash: 0388fbc98d49d874fb341b9037a743bc691d501f
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: French/France (fr_FR)
I think it comes from the default configuration of the 3D scene camera.NewJoker wrote: ↑Mon Dec 27, 2021 9:22 pm All right, thanks. I assumed that it’s not harmful to the model (apart from the fact that this corner can’t be selected) but I wondered if you know what causes it and if it can be fixed. Does it happen for everyone or only for some users ? Maybe specific hardware or OS configurations are affected by this glitch.
I have that kind of glitches from time to time and usually fix it with a View_FitAll.
In fact, I think the glitch is a hole, and you are selecting another face of the solid, that is in the background.
Werner explained it once, but I don't remember the details. As ChrisG has said, view -> fit all will fix it. I see this also sometimes as an inability to select a vertex, also corrected with view -> fit all.
