<Front shorcut '1'> fail with <Recent macro shortcut>
- Shalmeneser
My Std_ViewFront shorcut '1' fails if Preference > Macro > Recent Macro > Keyboard Modifiers is not set (void).
But i cannot change this with CTRL or SHIFT or ALT.
With a simple letter as modifier, '1' for 'Front' reworks.
- Capture du 2022-01-06 22-11-09.png (9.12 KiB) Viewed 1429 times
Re: <Front shorcut '1'> fail with <Recent macro shortcut>
Type in the string "Ctrl+Shift+" for example.
Edit: added the extra + after Shift.
Edit #2: added screenshot:
You could also set shortcut count to 0 for no shortcuts. Then there would be no conflict with the 1 key shortcut.
- Shalmeneser
Thanks.
I thought I had to type the concerned key (like in https://wiki.freecadweb.org/Interface_C ... n#Keyboard) and not their 'name'. Weird ?
Not weird. It should probably the same input technique for both dialogs. My fault it's not.Shalmeneser wrote: ↑Thu Jan 06, 2022 9:48 pm Thanks.
https://github.com/FreeCAD/FreeCAD/pull/5404 converts the line edit to a "key catcher" that sets up modifiers.
Maybe a way to warn user that changing default can lead to collisions could be a good addition too.
Merged by @wmayer.openBrain wrote: ↑Thu Jan 20, 2022 5:52 pm https://github.com/FreeCAD/FreeCAD/pull/5404 converts the line edit to a "key catcher" that sets up modifiers.
Would it be difficult to also check these dynamic shortcuts for conflicts on startup? We know what they are even if they are not yet created by checking these parameters: BaseApp/Preferences/RecentMacros (ShortcutCount and ShortcutModifiers). For example, if ShortcutCount = 3 and ShortcutModifiers = "Ctrl+Alt+", then we have:
Ctrl+Alt+1
Ctrl+Alt+2
Ctrl+Alt+3
We know without any modifiers there will be conflicts with the view menu shortcuts (unless the user has changed these).
Ctrl+Alt+1
Ctrl+Alt+2
Ctrl+Alt+3
Hi, I pushed a Draft PR implementing shortcut conflict detection and warning here : https://github.com/FreeCAD/FreeCAD/pull/5437TheMarkster wrote: ↑Mon Jan 24, 2022 5:48 pm Would it be difficult to also check these dynamic shortcuts for conflicts on startup? We know what they are even if they are not yet created by checking these parameters: BaseApp/Preferences/RecentMacros (ShortcutCount and ShortcutModifiers). For example, if ShortcutCount = 3 and ShortcutModifiers = "Ctrl+Alt+", then we have:
Ctrl+Alt+1
Ctrl+Alt+2
Ctrl+Alt+3
Main limitation is that we can detect shortcut collisions at the time menu is created/updated. If then another workbench is loaded that has some conflicts in its commands, it won't be detected. Is this acceptable ?
Can you look and tell me is it looks worth to you ? Because the PR also contains a fix for shortcut display in status bar. If the shortcut conflict detection looks useless, I will remove the latest commit and submit the PR without it.
Looks good to me.openBrain wrote: ↑Tue Jan 25, 2022 3:47 pm
