Is there a way to make errors beep?
lrak
Post by lrak »
The problems I have are usually with editing things. If I do something that creates an 'error' (red text in the 'Report View' box) and don't notice - I find it is possible to get a mess I can't recover from. The problem is I'm looking at the model I'm working on - and miss the errors.
I'm not a python programmer - but I think there is a play-sound lib - don't know how to load it or how to write something that will make the beep - so any help would be welcome. (I'm running on Debian bullseye - 0.19.. )
I would rather have questions that cannot be answered,
than answers that cannot be questioned’
Richard Feynman.
Re: Is there a way to make errors beep?
I don't know of a beep, but you can configure Preferences->Output window->Show Report on error.
That opens the report view, which should be alert enough.
mario52
Post by mario52 »
Hi
good idea adding option in "General > Output Window > CheckBox "Beep or Sound file..."
mario
TheMarkster
Post by TheMarkster »
This macro will set it so that you get a beep every time the text changes in the report view. I haven't worked out how to distinguish errors, warnings, and regular messages. I thought of using rv.textColor(), but it seems to always return black no matter even if the message is in red. There might be a way to move the cursor up to get the previous line, but I have failed with that, too.
from PySide import QtGui,QtCore
mw = Gui.getMainWindow()
rv = mw.findChild(QtGui.QTextEdit, "Report view")
def onMsg():
    QtGui.QApplication.beep()
modifiers = QtGui.QApplication.keyboardModifiers()
if modifiers == QtCore.Qt.ControlModifier:
    rv.textChanged.disconnect()
    FreeCAD.Console.PrintMessage('beep observer disconnected\n')
else:
    rv.textChanged.connect(onMsg)
    FreeCAD.Console.PrintMessage('beep observer connected\n')
Usage: run the macro to install the beep observer. Hold down Ctrl key while running to disconnect the beep observer.
report_view_beep.FCMacro
(445 Bytes) Downloaded 18 times
mario52
Post by mario52 »
Hi
TheMarkster wrote: Fri Jan 07, 2022 6:37 pm This macro will set it so that you get a beep every time the text changes in the report view.
you are too fast thanks
mario
TheMarkster
mario52 wrote: Sat Jan 08, 2022 10:41 am Hi
mario
I wanted to have the option to beep only for errors and warnings, but failed to make that work. It could be done in C++ code since the mechanism for opening the report view on these errors is already there.
To play another sound file:
from PySide2 import QtMultimedia
QtMultimedia.QSound.play("some_file.wav")
lrak
Post by lrak »
OK - This is great! - really appreciate.
I've spent a lot of time creating problems by trying to edit things and not realizing I've corrupted the object.
The little nudge from the beep really helps..
Richard Feynman.
