Addon manager issue with new build with Python 3.10
chennes
Re: Addon manager issue with new build
Post by chennes »
I don't see anything that jumps out at me in the Python 3.10 changelog -- I can't imagine your system has an old version of libssl, if it's already on Py3.10, and the other changes to urllib shouldn't affect us. I've got Manjaro downloading now, I should hopefully be able to spool that up in the coming days.
Chris Hennes
Pioneer Library System
drmacro
Post by drmacro »
chennes wrote: Sun Jan 09, 2022 4:25 pm I don't see anything that jumps out at me in the Python 3.10 changelog -- I can't imagine your system has an old version of libssl, if it's already on Py3.10, and the other changes to urllib shouldn't affect us. I've got Manjaro downloading now, I should hopefully be able to spool that up in the coming days.
Not sure I noted this previously.
The FEM issue during build happens when attempting use the AUR freecad-git package (not sure that's the right term). And the build fails.
But, if I do a git clone into a local freecad-source and build in freecad-build, the build completes. But Addon manager produces results discussed.
chennes
Post by chennes »
drmacro wrote: Sun Jan 09, 2022 4:33 pm But, if I do a git clone into a local freecad-source and build in freecad-build, the build completes. But Addon manager produces results discussed.
FEM is probably going to be over my head, but I can at least figure out the AddonManager issue. Would you mind adding "Python 3.10" to the subject line so I remember which thing this discussion is about?
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Sun Jan 09, 2022 4:37 pm
I was just adding that as possible clues, wasn't suggesting you work on it. ;)
Done.
chennes
Re: Addon manager issue with new build with Python 3.10
Post by chennes »
Well, the good news is that on a clean Manjaro VM I can reproduce your error. Of course, the bad news is, I can reproduce your error! But at least with a good example of the failure I can look into it now.
Chris Hennes
chennes
Post by chennes »
OK, it's an easy fix -- can you please try switching which line is commented out in addonmanager_utilities.py, around line 51, where it says:
    try:
        # ssl_ctx = ssl.create_default_context(cafile=certifi.where())
        ssl_ctx = ssl.create_default_context(ssl.Purpose.CLIENT_AUTH)
        # ssl_ctx = ssl.create_default_context(ssl.Purpose.SERVER_AUTH)
Comment out the middle one, and uncomment the last one, so you have:
    try:
        # ssl_ctx = ssl.create_default_context(ssl.Purpose.CLIENT_AUTH)
Chris Hennes
drmacro
Post by drmacro »
chennes wrote:
I have now tried today's git on two different Manjaro installs.
Addon manager works fine on one.
On the other I get this and it appears to hang (have to kill FC).
  File "/home/mac/freecad-build/Mod/AddonManager/addonmanager_workers.py", line 1135, in run
    self.run_git(target_dir)
  File "/home/mac/freecad-build/Mod/AddonManager/addonmanager_workers.py", line 1161, in run_git
    self.run_git_clone(clonedir)
  File "/home/mac/freecad-build/Mod/AddonManager/addonmanager_workers.py", line 1222, in run_git_clone
    if current_thread.isInterruptRequested():
AttributeError: 'InstallWorkbenchWorker' object has no attribute 'isInterruptRequested'. Did you mean: 'isInterruptionRequested'?
chennes
Post by chennes »
Sorry - so focused on testing the subtle that I forgot about the obvious... :? git commit 4cc744c92015ccd2b8ea6ba2ba4695b0e24461ef
Chris Hennes
ifohancroft
Post by ifohancroft »
I am getting the same problem on Manjaro with the new AppImage.
At first, I got the warning dialog about the addons there not being checked, etc. then when I hit Ok, I get the same error every time. It opens fine in an older AppImage.
Here's the FreeCAD info:
OS: Manjaro Linux (MATE/mate)
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Python on my machine is 3.10.1
`python` is /usr/bin/python which is a symlink to `python3` which is /usr/bin/python3 which itself is a symbolic link to `python3.10` which is in /usr/bin/python3.10
P.S. Going into preferences and changing from 'User-defined proxy' to 'No proxy' seems to resolve the problem.
I like making, breaking and modding stuff, using a soldering iron, code or both. https://ifohancroft.com
