bambuko wrote: ↑Sat Jan 08, 2022 6:53 pm
Thank you!
It would be interesting to compare it with Nav Cube code (and, no I haven't got a clue where and how to even start...
Firstly, I've not forgotten about this but due to the possibility of new users ending up with multiple entities over each other (Nav Cube, Frame Rate and Coordinate Axis) in the same corner I'm planning on the suggested code change being for power users only. As I'm in the middle of a serious house refurb the time required to deal with all the possibilities and prioritsation of which entity dictates the remaining positions of the others would be too much for me to commit to.
Therefore no UI change would be needed but the power user could add a parameter in
Tools>Edit Parameters to set the corner with the default (no entry or 1) being bottom right, each increment of the Integer would be clockwise the next corner, i.e. bottom left = 2, top left =3 and top right = 4. Realistically I should have something to demonstrate by the weekend and if acceptable I can then submit a Pull Request for the devs to look at.
If you feel this isn't sufficient then I can only suggest you raise a new topic in
Open Discussion with the title starting
[Feature Request] to include the the handling of the three corner positioned entities in the UI.
