Creating a textured station platform surface
Re: Creating a textured station platform surface
Good morning
I had problems with the length calculation in the 'LinearPattern' - It did not recognise Sketch002 despite it working before. I downloaded another copy and it also failed for the same reason. I decided to try and create my own modified file to see how things go.
This is the stage I am at and I have created the first LinearPattern which also would not accept the formula to calculate the length - so it looks like I have made an error but I did copy the formula correctly.
The changes I have made in this file is to use the calculations I made to fit the printer bed rather than using the previous settings (See bottom of page 1 of this thread). I used the calculated width (Y axis) and height (X axis) on sketch001 and the thickness of the base being the padding distance.
Sketch002 contained the first two blocks, as before.
To get round the issues with the formula not being workable, I simply entered the calculated length and the number Occurrences from my calculations.
When reviewing the result, I found a small discrepancy where the output was not symmetrical . An important requirement if I am to interlock end to end. Looking more closely, I could see that the reason for this was that I needed to extend the base by another dd dimension. This seems to have worked. I have not yet tackled the second LinearPattern. Comments would be welcome. Thanks.
Kind Regards
Peter
Kind Regards
Peter
- Shalmeneser
Have you change FreeCAD version ? Some recent 0.20 version had problems.
Last one is ok.
Thanks for your reply.Shalmeneser wrote: ↑Fri Jan 14, 2022 1:44 pmHave you change FreeCAD version ? Some recent 0.20 version had problems.
Last one is ok.
OS: Windows 10 Version 2004
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Kind Regards
Peter
I have now created the second linearPattern (X-axis).
I had the same trouble with the formula. Until I know what is going wrong, I continued with the calculation method to balance the padding distance, x-axis, and the length value for the LinearPattern. It was great to see in the 3D view how my adjustments were going
I have revised the File issue to 3.1. File below Now on to the MultiTransform.
You have two dots after "Sketch002".
- Shalmeneser
It is not a big issue. I accepted it was my probably my error when It first arose. At least it made me learn how I had to accommodate the issue by manipulating the program features - On a positive note I might add. Also, using FreeCAD features beats trying to do things manually and I am very grateful for the support helping me to achieve this.
Kind Regards
Peter
Occurrences should probably have something in front of it, like Constraints.Occurrences, Spreadsheet.Occurrences, etc.
I am really struggling with the MultiTransform.
To set this up I selected the body and pressed space to make it active. I then selected MultiTransform and it listed the available features, which included the the two LinearPattern features. I selected the 'inearPattern X axis' and received the message 'Transformation Successful' message. Pressing the OK buttonbrings me back to the tree. Selecting the Multitransform again I get the dialog telling me that LinearPattern x axis succeeded. Looking to add the other transformation, I right clicked in The Transformations box, selected LinearPattern to add and the list def and instead of offerring LinearPattern Y axis, LinearPattern002. The Message window advised 'Only additive or Subtractive features can be transformed'
I propably missed something The Multitransform instructions. Can someone please help?
Thank you
Thank you
