Thanks for that. I shall check the formula that I copied and take the opportunity to retest using the formula. I shall post on here what I find.TheMarkster wrote: ↑Sat Jan 15, 2022 12:35 am Occurrences should probably have something in front of it, like Constraints.Occurrences, Spreadsheet.Occurrences, etc.
Creating a textured station platform surface
Re: Creating a textured station platform surface
Found reference file Snips for LinearPattern and LinearPatternoo1 Edit I shall hold off re-trying the formula until I get the all clear, ThanksPeterSD wrote: ↑Sat Jan 15, 2022 12:46 amThanks for that. I shall check the formula that I copied and take the opportunity to retest using the formula. I shall post on here what I find.TheMarkster wrote: ↑Sat Jan 15, 2022 12:35 am Occurrences should probably have something in front of it, like Constraints.Occurrences, Spreadsheet.Occurrences, etc.
Kind Regards
Peter
Make it LinearPattern.Occurrences or LinearPattern001.Occurrences.
Thanks very much, I shall try that in the formula and post another reply here.TheMarkster wrote: ↑Sat Jan 15, 2022 3:11 am Make it LinearPattern.Occurrences or LinearPattern001.Occurrences.
Kind Regards
Peter
UPDATE
I changed the formula for both. It allowed me to update but when I go back, I find the formula has reverted to what it was.
I have limited this action to the reference file at this time
Coming back to my file. I have now successfully entered the formula into both LinearPattern features and up issued the file to Rev 3.3.
Kind Regards
Peter
The reasons for the previous failures were all mine.
- 1
- 2
Kind Regards
Peter
- Shalmeneser
In 0.20.27008, 'LinerPattern.Occurences' will be automatically changed to 'Occurences'.TheMarkster wrote: ↑Sat Jan 15, 2022 12:35 am Occurrences should probably have something in front of it, like Constraints.Occurrences, Spreadsheet.Occurrences, etc.
- Shalmeneser
PartDesign_LinearPattern
Your construction tree let me think you need only MultiTransform (like in my perfect file ).A LinearPattern cannot be applied directly to another pattern, be it polar, linear or a mirror. For this you need a PartDesign MultiTransform..
- Capture du 2022-01-15 18-49-38.png (22.08 KiB) Viewed 766 times
I thought that this oicture might help understand what is going on.
The formula makes this length 12.6
Something similar must be happening along the Y axis but I have not checked this yet.
The first two steps in the x-axis would be fixed by sketch002 and everything else would be determined by the formula. There appears to be a 4mm reduction in step for the next pair of steps. That is the distance travelled on the X axis to of the second pair. The length should be 16 +1.2=17.2The formula makes this length 12.6
- Shalmeneser
Your sketch is bad imperfect :
* Zero-dimension : try always to replace a dimension with a geometry when it's possible.
* 6-dimension : if this 6 is the half ot the 12, geometry should translate this (like in my sketch ).
- Capture du 2022-01-15 18-59-57.png (10.56 KiB) Viewed 749 times
Thanks for that. I had replied to that suggestion early this morning to TheMarkster having proven just that is the case.It reverted to just 'Occurances' as you have said.Shalmeneser wrote: ↑Sat Jan 15, 2022 5:47 pmIn 0.20.27008, 'LinerPattern.Occurences' will be automatically changed to 'Occurences'.TheMarkster wrote: ↑Sat Jan 15, 2022 12:35 am Occurrences should probably have something in front of it, like Constraints.Occurrences, Spreadsheet.Occurrences, etc.
