Automated fault checking
Vagulus
Post by Vagulus »
I guess I am not alone in that I make mistakes while creating 3D models in FreeCAD :roll: so I am interested in any help I can get to ensure that the sketching step is error-free before I move on. When I am about to save a sketch I like to get the message 'Fully constrained Sketch' and I have found two other automated checks: Part --> Part --> Check Geometry and Sketcher --> Sketch --> Validate Sketch.
Are there others? Is there one, giant 'Validate Body' check?
"It is much harder to simplify than to complicate."
Joseph Kimble
drmacro
Re: Automated fault checking
Post by drmacro »
- Recompute and check report view for errors.
- Check Dependency Graph for red arrows.
Vagulus
Post by Vagulus »
chrisb wrote: Fri Jan 14, 2022 1:38 am - Check Dependency Graph for red arrows.
I downloaded and installed windows_10_cmake_Release_graphviz-install-2.50.0-win64.exe
After reboot I tried it and FC popped a dialog saying it still wasn't installed. Some DLL unreadable problem.
Is the install file corrupted?
Joseph Kimble
Vagulus wrote: Fri Jan 14, 2022 5:10 am Is the install file corrupted?
You should add where you downloaded it, so others using the same can check.
Vagulus
Post by Vagulus »
Just followed the link from the Wiki.
https://graphviz.org/download/#windows
Joseph Kimble
heron
Post by heron »
Vagulus wrote: Fri Jan 14, 2022 5:10 am After reboot I tried it and FC popped a dialog saying it still wasn't installed
In that same dialog window it gives you the option to choose the path where it is installed. Did you try this option?
Vagulus
Post by Vagulus »
I don't know which EXE file to list. There are a few in the BIN folder.
Joseph Kimble
heron
Post by heron »
only select the folder
I don't know what exactly the windows install is looking for, but the program actually used is dot.exe.
