Page 1 of 1
Techdraw wrong views some lines missing
Posted: Fri Jan 14, 2022 7:53 pm
by ottos888
Dear Users! In techdraw workbench the section looks different than it should. Some lines are missing, some I dont know how it came there. And the detailed view does not have the hatch. How can I make it work? And is there a way to set the depth of the section (like I only want to see 100 mm from the section) . Thank you for your repleys.
The file name is the following:" A 02-01 PC asztal oss"
Re: Techdraw wrong views some lines missing
Posted: Sat Jan 15, 2022 2:36 pm
by wandererfan
ottos888 wrote: ↑Fri Jan 14, 2022 7:53 pm
https://www.forum.freecadweb.org/viewto ... 13#p559513
As mentioned in my reply to your previous post, A2P assemblies sometimes are not suited to further processing. Both the Section and Detail views require Boolean Operations to be performed on the assembly in order to produce the drawing geometry. If the result is suspect, the drawing will be wrong.
Hatching is performed separately on each View. The Detail view does not know what faces are hatched in the Base view.
