Learning to use the cross-section macro
Vagulus
Post by Vagulus »
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
I have an assembly (Assembly4) which I am trying to cross-section. I execute the macro and get
220115 X-Section Failure 1.png (74.05 KiB) Viewed 1262 times
I am confused. :? I can see the assembly on the 3D View. What does the error dialog mean by 'no visible solid objects'?
"It is much harder to simplify than to complicate."
Joseph Kimble
mario52
Re: Learning to use the cross-section macro
Post by mario52 »
Hi
tray the upgrade by alepho (the creator) cross-section macro
mario
Vagulus
Post by Vagulus »
mario52 wrote: Sat Jan 15, 2022 10:56 am tray the upgrade by alepho (the creator)
I wouldn't know what to do with the code. I installed it with add-on manager assuming that it would be up to date. Where would I get the new version installed?
Joseph Kimble
mario52
Post by mario52 »
Hi
Vagulus wrote: Sat Jan 15, 2022 11:05 am I wouldn't know what to do with the code
edit the macro already installed delete the code and paste this code , save and run
no other code
mario
Vagulus
Post by Vagulus »
mario52 wrote: Sat Jan 15, 2022 2:07 pm edit the macro already installed delete the code and paste this code , save and run
Hmmm! :|
Did that but now I don't even get the dialog.
I replaced the code as you said and if I 'Execute' the macro nothing happens at all. If I DLC on the macro the 3D View goes blank and I have to restart FC.
Before you ask, I restarted FC and I have rebooted my PC. No difference! :(
Joseph Kimble
mario52
Post by mario52 »
Hi
I don't know you tray the two macro available
maybe the problem is the macro is used with one assembly
tray the domad method Sezione Dinamica
or contact the author
sorry
mario
drmacro
Post by drmacro »
For reference, it appears the version of the macro currently in Addon manager does not produce valid solids with FC 0.20 and OCCT 7.6.
I noted this in this thread:
https://forum.freecadweb.org/viewtopic. ... 77#p562177
Vagulus
Post by Vagulus »
drmacro wrote: Sun Jan 16, 2022 1:27 pm For reference, it appears the version of the macro currently in Addon manager does not produce valid solids with FC 0.20
That would certainly explain why I get no result when I use the version of the macro currently in Addon manager. :D
This will always be a problem with a program which is constantly developing in an Open Source environment - coordination. Someone changes something to make an improvement or an advance and that change adversely affects some apparently unrelated functionality.
I guess we mortals will have to wait on the good devices of the Author and hope that a new version will appear. ;)
Will there be some general notification when that happens?
Joseph Kimble
drmacro
Post by drmacro »
Vagulus wrote: Sun Jan 16, 2022 9:00 pm
If you check the other thread, the model is good, you just have to explode the compound it creates. Then the result is valid. Thanks @TheMarkster for pointing out the details.
