When I switch from the "Sketch" and "Arc", I often get the following appearance, see attached file.
Why is that?
How do I reset so that the structure object is on the grid again (and does not cut through it)?
Thanks for the reply!
Tomas
Construction loses the coordinate system
Re: Construction loses the coordinate system
That grid is the Draft workbench grid.
Turn it of with the key sequence G R.
It is toggled on by selecting the Draft workbench.
You can change that behavior in Edit>Preferences>Draft
Thank you Drmacro!
Your solved my problem
/Tomas
/Tomas
