I am trying to apply the following expression to the vertical 1000mm constraint in the sketch in the attached file:
Constraints.def/2
For some reason this results in a "Failed to parse expression" error. I do not understand what is causing this.
Sketch: mysterious "Failed to parse expression" error
- Window with 2 vertical fixed glass.FCStd
- (17.08 KiB) Downloaded 16 times
Re: Sketch: mysterious "Failed to parse expression" error
Did you try to replace 'def' with something else? It may be a reserved word.
FreeCAD infos? There were recently issues reported with expressions.
No problem here.
OS: macOS 10.16
Version: 0.20.27008 (Git)
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
- def_cb.FCStd
- (11.27 KiB) Downloaded 8 times
Version info:
It seems to be related to the file.
Version: 0.20.26858 (Git)
Hash: e209bc706d35121098f9bac779bc6b09c24ddd95
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- thomas-neemann
what crisb did works here too
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.27008 (Git) AppImage
Branch: (HEAD detached at 9162733)
Hash: 91627338a44371fe9a8e815b4900f62558af98a1
Qt version: 5.12.9
OCC version: 7.5.3
Recreating the problematic dimensional constraint solves it.
