Draft Workbench Bug (which leads to a crash)
MRx
Post by MRx »
OS: macOS 10.15
Version: 0.20.26556 (Git)
Branch: adaptive_dicretize_bugfix
Hash: 4357816c94ff4938b778eb9f8aba8fe0e1c917dc
Python version: 3.9.0
Qt version: 5.15.2
OCC version: 7.5.0
Locale: English/Germany (en_DE)
09:58:25 Traceback (most recent call last):
File "/Users/markus/devel/freecad/build/Mod/Draft/draftutils/todo.py", line 167, in doTasks
Gui.doCommand(string)
NameError: name 'nan' is not defined
09:58:25 ToDo.doTasks, Unexpected error:
<class 'NameError'>
in ['pl = FreeCAD.Placement()', 'pl.Rotation.Q = (-0.7071067811865475, -1.48949964615761e-14, 1.4916645362981988e-14, 0.7071067811865476)', 'pl.Base = FreeCAD.Vector(264.4811932979572, -8.499999999999945, -1.6146078033251756)', 'rec = Draft.make_rectangle(length=nan, height=nan, placement=pl, face=True, support=None)', 'Draft.autogroup(rec)', 'FreeCAD.ActiveDocument.recompute()']
first of all I'm selecting the two lines in the draft workbench
afterwards I click "current working plane" (the two lines should align the working plane to it)
Afterwards I set the snapping rules:
Snap Lock
Snap Endpoint
Finally I try to connect the two lines with a 2 point rectangle, in the property window I'm getting NAN mm if I try to snap to the edges.
Also the screen flickers here, maybe those values are passed forward to coin3d which cannot handle it.
Now in my big object it's guaranteed that freecad will crash if I proceed with clicking, in that cutout example (where I copied the two particular edges) it doesn't crash but prints errors.
draftcrash.FCStd
(3.21 KiB) Downloaded 17 times
Roy_043
Re: Draft Workbench Bug (which leads to a crash)
Post by Roy_043 »
I have tested your scenario, and I can't confirm: no crash and no errors. I have created 4 Draft_Rectangles using a different endpoint as the first point each time. Draft has an "internal precision level" setting and a "Tolerance" setting. It may be worth looking at those: Draft_Preferences#General_settings. But I have my doubts if they are the cause here.
OS: Windows 8.1 (6.3)
Version: 0.20.26761 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
draftcrash-no-crash-roy.FCStd
(9.23 KiB) Downloaded 9 times
MRx
Post by MRx »
Did you see the "NaN" and flickering? Yes the crashing only happens on my larger object (where I took those two lines from)
Tolerances in FreeCAD seem to be messed up the real settings aren't applied everywhere it seems, and I'm having big trouble to fix those problems.
Roy_043
Post by Roy_043 »
MRx wrote: Tue Jan 18, 2022 9:04 am Did you see the "NaN" and flickering?
No, and No.
MRx
Post by MRx »
the flickering did not happen this time either, however it did lead to a crash on the original object.
The NaN problem is still reproducible (and possibly causes other issues in the background when passing the values forward).
Roy_043
Post by Roy_043 »
You did not mention that you also have Draft_Snap_WorkingPlane activated.
But repeating my test with that snap additionally activated still shows no issue.
Try upgrading FreeCAD. If that does not help it may be OS related?
Syres
Post by Syres »
MRx wrote: Tue Jan 18, 2022 2:06 am Now in my big object it's guaranteed that freecad will crash if I proceed with clicking, in that cutout example (where I copied the two particular edges) it doesn't crash but prints errors.
Here's the output (no errors or crash) compiled from today's master using two different OCC's on Linux, Python Console output so you can see I followed the steps:
FreeCAD.openDocument('/home/john/Downloads/draftcrash.FCStd')
# App.setActiveDocument("draftcrash")
# App.ActiveDocument=App.getDocument("draftcrash")
# Gui.ActiveDocument=Gui.getDocument("draftcrash")
Gui.runCommand('Std_OrthographicCamera',1)
App.activeDocument().recompute(None,True,True)
### Begin command Std_Workbench
Gui.activateWorkbench("DraftWorkbench")
### End command Std_Workbench
# Gui.Selection.addSelection('draftcrash','m','Edge2',263.174,-8.5,-2.86252)
# Gui.Selection.addSelection('draftcrash','m','Edge1',264.479,-8.5,-2.51827)
FreeCADGui.Snapper.setGrid()
# Gui.Selection.clearSelection()
Gui.runCommand('Draft_Rectangle',0)
# Gui.Selection.addSelection('draftcrash','m','Edge2',263.174,-8.5,-3.7583)
import Draft
pl.Base = FreeCAD.Vector(263.174194, -8.5, -1.653000000000008)
rec = Draft.make_rectangle(length=1.3051960419998068, height=2.146999999999992, placement=pl, face=True, support=None)
# Gui.Selection.addSelection('draftcrash','Rectangle')
# Gui.Selection.addSelection('draftcrash','Rectangle','Face1',264.474,-8.5,-1.67202)
Report View output:
12:16:57  Draft workbench activated.
12:17:05  ----------------
12:17:05  GuiCommand: Rectangle
12:17:05  Pick first point
12:17:08  Pick opposite point
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.27089 (Git)
Hash: ead1bce8e994358388fd6dd993f0c9b756ec0eac
Python version: 3.6.9
Qt version: 5.9.5
Qt version: 5.9.5
OCC version: 7.6.0.beta
MRx
Post by MRx »
There's a bug with Coin3D in the Draft workbench which can crash FreeCAD. I'm always starting FreeCAD on the same console, I have around 20 crashes in the backlog of the terminal.
Something might fail with listeners and duplicate registration (not particular from one part, but from another part of the code) might fail.
This is something to watch out for.
I had the same issue with some Path modifications which I have added in my local FreeCAD version.
The draft workbench has several smaller issues, eg. Draft to Sketch re-position the sketch to the origin of the object, the user has to fix the position himself at the moment.
drmacro
Post by drmacro »
I never need to fix positions...
I also can't confirm the crash, tried several scenarios.
MRx
Post by MRx »
Yes, the file is fine, first you need to enter an unstable state in the draft workbench - then you would see it. I still need to figure out how to enter the unstable state. It happens regularly here so I should be able to figure that out within the next days.
