Speed challenge non-parametric model
- thomas-neemann
i had started this model in draft/part and someone wrote: "I can definitely do it quicker in Part Design sketcher... I suppose each to his own"
here is an uncut video where it's finished under 2 min.
https://www.youtube.com/watch?v=DhZ576wnyrU
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
Re: Speed challenge non-parametric model
I am still drinking my coffee (half asleep ) but after I had my breakfast I will have to time it and either prove me right or eat my hat
OK, I had my hat for breakfast
You win Thomas.
Having said so, I will continue using (and preferring) Part design, even if it means some time penalty
To each his own (or De gustibus non est disputandum)
You win Thomas.
- thomas-neemann
there is a good solution for "everything" in freecad, e.g. tangents in the sketcher, the form bevels in partdesign.
it is often clear from the outset that there will never be any changes. it should only be finished quickly, then draft is very interesting. if it's supposed to be parametric, there's no way around sketcher
And now to the next challenge: The customer wants this in 5 different sizes.
- thomas-neemann
there will be a number of variants from when a parametric model is worthwhile. in this model, I suspect about from the second variant
- adrianinsaval
it took me 1:20 (second try from the ground up after figuring out PD thickness doesn't like this shape) using sketcher instead of draft, note that offset 2D is parametric too. Also with this feature it would be possible to have a similar workflow of entering dimensions while sketching (I didn't use this now): https://forum.freecadweb.org/viewtopic.php?f=9&t=65279
I have no screen recording software in this computer so I hope you can trust my timer: I can make a video later if you're interested in the how to, no guarantee of repeating the same record
- challenge.FCStd
- (14.98 KiB) Downloaded 19 times
My heroadrianinsaval wrote: ↑Tue Jan 18, 2022 2:10 pm it took me 1:20 (second try from the ground up after figuring out PD thickness doesn't like this shape) ..
must keep practicing to improve my speed as well
- thomas-neemann
this is a very good result. The tool is very interesting, I hope it will be included in the master.adrianinsaval wrote: ↑Tue Jan 18, 2022 2:10 pm ...Also with this feature it would be possible to have a similar workflow of entering dimensions while sketching (I didn't use this now): ...
My take.
It really depends on your workflow. I could never do a similar time with Draft, because I simply don't use it to draw things...
- Challenge.png (25.04 KiB) Viewed 991 times
- Snip macro screenshot-bebd95.png (86.76 KiB) Viewed 991 times
