Fillets and curves
idris
Fillets and curves
Post by idris »
I'm experimenting with fillets and curves.
Sometimes when I create pads from sketches with curves, I can fillet the curved edge where it meets another flat face. Sometimes I get a message "Failed to create" and I can't figure out what conditions need to be met for a curve to be filleted.
Any thoughts?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
drmacro
Re: Fillets and curves
Post by drmacro »
There are conditions with fillets/chamfers.
  • the fillet radius can't result in consuming an adjacent edge
  • since the fillet process follows edges, it has difficulty when the edge leads to an intersection of 3 or more edges
  • since the fillet process follows edges it is best to make sure any transition from edge to edge or edge to curved edge is tangent
  • fillets between round features will most likly fail (especially a round feature that is tangent to another feature, think the intersection of two pipes of the same radius)
  • Sometimes it is best to set the Refine property of the last feature to true before attempting to fillet
Fillets are highly susceptible to Topological Naming Problem. Thus changes in previous tree features are likely to cause issues with fillets.
drmacro wrote: Tue Jan 18, 2022 1:02 pm
Good comprehension. (Point 4 is a possibility to avoid point 2.)
idris
Post by idris »
Any suggestions on how to fillet the highlighted edges (though not necessarily all with the same radius)?
Shalmeneser
Post by Shalmeneser »
File ?
drmacro
Post by drmacro »
idris wrote: Wed Jan 19, 2022 10:58 pm Any suggestions on how to fillet the highlighted edges (though not necessarily all with the same radius)?
Did you read my 4th point...this is an example. :lol:
idris
Post by idris »
Yes, I read it, and realised this fitted that category.
I was hoping there was a solution :|
Would it be possible to use a Sweep rather than a fillet? My gut says yes, but my head explodes when I try to work out how to do it.
hammax
Post by hammax »
... a small dimension difference and refinement may solve the "fillet intolerance" - as drmacro said
Fillet_3.FCStd
FC.19.3
(342.29 KiB) Downloaded 9 times
Fillet_2.FCStd
FC.19.3
(59.71 KiB) Downloaded 6 times
Fillet.FCStd
FC.19.3
(44.49 KiB) Downloaded 7 times
domad
Post by domad »
Hi idris, greetings to the Community!
Without the availability of the original file, you can only outline some solutions, four examples of filleting are attached, but I don't know if they are right for you.
fitting.FCStd
(948.22 KiB) Downloaded 18 times
