Problem with Helix creation
Vagulus
Post by Vagulus »
I wish to create an helix with an oblique quadrilateral cross-section. Helix works fine with a simple circle but refused to work with the drawn cross-section. I have done all the checks on the cross-section sketch I can think of but it just won't create a screw.
Would someone please tell me why not.
Pitch 70mm
Radius 100mm
Turns 1
Thanks
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
220118 Helical Concept.FCStd
(89.58 KiB) Downloaded 15 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Grub
Re: Problem with Helix creation
Post by Grub »
In your sketch, you need to convert your 2mm segment into construction geometry:
https://wiki.freecadweb.org/Sketcher_ToggleConstruction
drmacro
Post by drmacro »
You have a Tee intersection in the profile.
Snip macro screenshot-00ec3c.png (106.74 KiB) Viewed 513 times
Vagulus
Post by Vagulus »
drmacro wrote: Tue Jan 18, 2022 1:41 pm You have a Tee intersection in the profile.
Thanks for pointing me in the right direction.
The problem was that the cross-line was not a construction line.
When I made it a construction line the right angle constraint did not matter.
All good now. :D
Joseph Kimble
