solved: failed loft (v.19)
Re: failed loft
You can either use a pad "To first" or let the loft go through and cut off the excess.
Re: failed loft
Hi byakk0, greetings to the Community!
Attached is an example (many can be done) of how it could be done.
- mirrorStand.fcstd
- (362.46 KiB) Downloaded 12 times
- mirrorStand.png (276.88 KiB) Viewed 461 times
Re: solved: failed loft (v.19)
That's great. That base is nearly the same as mine, at least looks wise.
I'm designing ground up to fit the internals of a Miata power mirror.
I'll have a look at that one if I need.
~~Hazen
